Wanted to borrow a helmet suitable for a track day Aug 8th
I only have a motorcross one! Haha
I've seen people wearing half face helmets out at Mallala plenty of times, you might get away with it, if not borrow one off one of the 75% of people that aren't racing at the time. I've seen plenty of people lending fire extinguishers and helmets like this as well.
i use my motocross helmet :D
  • 3 weeks later...
hey, does anyone have a pink label afm i could borrow? just need to double check if mine is stuffed.
pm or email
[email protected]
cheers
daniel
ive got one you can borrow but you cant keep it long as its off my car lol
pm or email
[email protected]
cheers
daniel
Hey - if this is the same as the R34 Neo ones - I have one - I just lent it out to RubyRS4 - you're welcome to it next if you want.
pm or email
[email protected]
cheers
daniel
Ill help you out mate i got a spare one you can compare yours with! text me on 0423412092
if anyone knows someone or has one themself, i'm looking for a drivers side sr 180 seat just to get me through regency.
i can lend you the race seat that's in my 180 if i can borrow your standard seat just for regency. we'll do the swap over the day before or something to make thing's easy.
cheers
cheers
Kye, ask Brad, his car is regency spec atm, you could probably borrow his seat.
hey all... im looking for two 17x8's in four stud to go on the front of my 31... just rims.... just for the nationals track day... dont care what they are, just need to be round.. and not need spacers...
Hey nugzy, i got some black 17x9's you can borrow with 235's on them.
Also does anybody have any 5 stud rims i can borrow for a while to fit on my skyline while i get some rims sorted out for it? Tyres can be bald as it wont be driven at all. Will probably need them for a month.
do they need to clear brembos chad? if not ive got the AVSs sitting here doing nothing
Thanks guys, Might grab those AVS's off you Matty as I know they will clear the GTR brakes. I'll send you a msg at some stage and organise picking them up.
Edited by DSTROY
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
