Good new tyres will be going on hopefully at the start of next week after I get it registered. Compliance put ten year old rubbish on it. It’s ridiculous that compliance workshops can put such unsafe crap on a car.
Still after an air box and snorkel if anyone can lend me one.
Good new tyres will be going on hopefully at the start of next week after I get it registered. Compliance put ten year old rubbish on it. It's ridiculous that compliance workshops can put such unsafe crap on a car.
pretty sure BITSUS is selling one if your desperate
  • Like 1
  • Nope 1
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
