hi, guys i'm thinking about upgrading my front brakes to brembos, what do you guys think? is it a good idea? i would rather over brake then under brake. ive got a few question that i have
1) how easy will it be to get the brembos on?
2) what will need to be changed?
3) and they should fit under the normal R33 gtr wheels right?
4) anything i need to know that i dont know?
any input would be great. thank you guys
https://www.sau.com.au/forums/topic/220853-r33-brembos-on-r32-gtst/
few more things i should add i'm running a R33 turbo so should be at about 190rwkw, and i'm also getting these for 825 AUD, is that a good price? for just the fronts with DS2500 pads, and the standard discs. they off a 1997 gtr.
any advice would be good guys.
thanks
1. Should be a direct bolt on fit (34 gtr use diff size bolt, 32/33 are the same)
2. The caliper, disk and i would also put on ADR braided lines
3. Dont see why not as that is how they came from factorie.
4. I would also change the brake fluid and if it were me the master cylnder to a gtr as it is larger or inspect your one and if need be change the seals.
GTST's are not the same, the bolts to the hub are a different diameter for a start.
What about the 280 mm rotors versus 324 mm rotors?
You need calliper adaptors (try UAS), rotors and brake lines.
Changing the fronts only is not a good idea, I would do the rears at the same time.
Personally I think the Brembos are overrated and not good value for money. They are hardly any better than the standard Sumitomo/Nissan 4 spot fronts and 2 spot rears.
Cheers
Gary
If you want to run an R33 or R32 Brembo caliper on your R32 GTSt then they are almost a bolt on affair. You need to use the GTR rotor (324mm) which once the caliper is off requires you to cut off the dust guard and then simply slide on, easy.
Next you will find that the bolt whilst the same diameter is a different pitch . So the bolt will easily go through the hubm, you just need to either buy a new bolt (good idea) or make sure you GTR calipers come with the bolts as well. Then its a matter of bolting up the lines (striaght fit) install pads and bleed brakes.
If you use R32 or R33 calipers and rotors then its as near to a bolt on job as you get with cars. If you have an R34 simply grab R34 GTR calipers which are cheaper as there doesnt seem to be the demand as there arent that many R34 owners compared to R32/33 owners chasing them.
Shameless plug, if you want to run Brembos then i have some F40 calipers that run the GTR rotor for sale, better more flexible setup with near new rotors and better caliper for the same asking price as used GTR gear :down:
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
