a 272 is one of them poxy ass hks cams though...youd want something like a 270 from tomei :laugh:
me personally i wouldnt go any lower than 270 10.25, i've be more inclined to go with the 10.8, depends on the rev limit too though
https://www.sau.com.au/forums/topic/220927-cams/#findComment-3895690
Mine has Jun 272 / 10.5 inlet and 280 / 10.8 exhaust. I didn't fit larger exhaust valves to this head and the longer exhaust duration and higher lift is there in an attempt to compensate for the standard mismatch in valve sizes.
Cheers
Gary
https://www.sau.com.au/forums/topic/220927-cams/#findComment-3898037
so going the larger lift is fine?
Why do you think it might not be fine?
Plenty of clearance to the piston crowns, if that's the question.
i thought it might get to crazy
Too crazy for what?
The extra 20% capacity of the 3 litre makes smooth what feels like lumpy cams in a 2.6.
im happy to go larger if need be
More lift won't hurt, but I wouldn't be going for more than 272/280 duration, the RB30 doesn't need the rpm range that longer duration would provide.
is it worth mixing up the overlap?
An often argued question, for which I don't believe there is one correct answer. I only went for the longer duration so that I could get the higher lift on the exhaust cam as I know the exhaust valves are too small in proportion to the inlet valves. For the RB25.5 I used larger exhaust valves with the same lift and duration cams on both inlet and exhaust.
Cheers
Gary
https://www.sau.com.au/forums/topic/220927-cams/#findComment-3898561
sounds like 270 10.8 lift both sides
ill be upgrading valves all round
head guy said 10.2 lift is easy and when you go 10.8 it gets alot tighter( eg more bucks! mainly due to more work and more expensive springs becasue of potential bind and rates)
anyway bigger is better and faster
hopeully all teh head work will fully utalise the gtrs's
https://www.sau.com.au/forums/topic/220927-cams/#findComment-3901159
What is the limiting factor stopping you going bigger?
other then having no lift available bigger then poncams 260 for NEO i was also told by spool who is using same head. Cant exactly remember how he explained but its the way the Head is design. You think they are too small?
https://www.sau.com.au/forums/topic/220927-cams/#findComment-3907189
No, its just that im about to fit larger lift cams to a neo head(already dummy fitted them) from an rb26
https://www.sau.com.au/forums/topic/220927-cams/#findComment-3907238
thats interesting. what lift are your cams? As a matter of fact mine are GTR cams aswell. NEO head has similar solid lifter design to rb26. Cams are fully bolted in and head assembled with no problems. Apparently any lift bigger then 9.3 ish exposes the oil something or rather. Anyone know what kind of power levels the poncam can or have supported?
https://www.sau.com.au/forums/topic/220927-cams/#findComment-3909786
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
