  • Replies 97
Posted Images
Yo, man. My GTT is basically a RWD GTR.
600rwhp with a RB26DETT transformed to a RB27DET and a GTR tranny mounted underneath.
I NEEDED the MFD to monitor my car's vitals signs so I can help avoid trips to the Skyline doctor.
  • 1 year later...
Lol he be mad because he's only got a 32 and this swap won't work for him.
so... I have a R31 and I am about to go full custom with one of these.
question as well. I see a tach input on this - can I get a TACH gauge up on this unit at all?
I have pulled the tach out of my dash to put this display in place.
(and 2yr thread bump ~ !~)
Lol actually thinking of putting one in my ralliart colt, but so many better aftermarket options out there.
Oh good to see u still around chris.
yep still around , still screwing with old nissans..
Chris, There is no way to show RPM on the unit itself. The RPM input is used to trigger (at a desired point) the REV shift light on the unit. Let me know if you have any questions as I have just finished installing one of these (properly) into my GTT.
got this one on the bench and went looking. looks like I lost the tach in my car. its auto and no biggie.
progess shots: (reverse engineering the switches and video display at that point.)
1098176_10201795206065101_1210220218_n.j
anyone have an exact translation of the G sensor pinouts. I have the HK PDF but the pinuts for brown 25.26.28.29.38.39.40.44 are VERY vague as to function.
Chris, see attached image file. I copied this right from the Nissan R34 GTR Supplemental Manual. It has all the trouble shooting stuff and pinout for the MFD. Maybe it makes more sense than the HK translated one to you.
  • 8 months later...
Hi everyone,
I' settling the nismo upgrade on my GTT's MFD.
Does someone know how to install the exhaust sensor?
I mean like a tutorial of the set up?
Do I need to drill a hole or buying a v-spec pipe for example?
Thanks for the reply,
Oh if it could help, I have the Japanese manual and if needed I can take some picture of the two different board side to side while I will install it.
Really it wouldn't be worth it to go and find a V-Spec pipe to install the sensor, and it's not like it would just fit if you did get one.
1. Drill hole pre-cat but away from turbo dump (i installed mine 2cm before cat).
2. Weld bung in to accommodate sensor.
3. Screw sensor in and run wiring up through floor grommet under passenger seat.
4. Terminate 1 sensor wire to eyelet and bolt/screw to floor pan under seat.
5. Extend other sensor wire (it doesn't matter which), to the MFD display neatly and connect to exh. temp. sensor pin.
Don't forget to reinitialize the unit after start up to detect the sensor (and inter-cooler sensor if your installing that too). Although i guess you have to do that anyway since your installing the Nismo board.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
