ok its been worrying me a fair bit lately, it dosent take a genious to understand that on a cold engine there is no oil around the engine on a cold startup, so on that note, just a quick question, is the car meant to run at higher revs on cold startup then as it gets warmer the revs come down? it almost brings a tear to my eye when i start the car up in the morning and it revs its tits off and slows down.
is this normal?
https://www.sau.com.au/forums/topic/221100-revs-on-cold-startup/
the longer the engine is cold, the worse the performance, economy and emissions are
the engine's ideal operating temp is 80deg so it does everything possible to heat itself up to 80deg
so below 80deg the ecu adds in fuel and ignition correction to get to operating temp quicker
paul on that comment, are you saying that the longer it takes the engine to warm up to operating temp, the worse it will performe etc.? as in for best performance and economy (at operating temp) its best to warm the engine quicker?
its better to have the engine warm up as quickly as possible, the best way to do this is drive it around normally but dont trash it
tactics such as leaving an engine idle for a 5 minutes before you take off for work is bad, as engine runs colder for longer than it normally would
so drive it around, just dont trash it till the engine temp is up near 60-70deg then its ok for some normal load etc
i usually just baby it around for first few minutes by the time im near the freeway entrace the water temp is well past 55deg so its fine after that
what happens if you do happen to trash it when its cold? does it wear out the engine more?
not that I do it :down:
i used to have a VH commodore, and when starting, would have to apply 50% (keep the engine running) tactics, and 50% (not let it die) tactics, so naturaly the lower the revs the better in that case, because it had no oil at the engine when starting. thats why i asked :down:
An idling engine below 2,000rpm is doin far less damage then when you first pull away and change gears at prolly 3,000rpm+ with the engine under load... So I would not shed a tear on startup, just dont rev out the car at all in the first 10mins... It suprising how long the oil gauge takes to rise... made me realise how useless the water temp gauge is!
Edited by r32line
so your saying its better to let the car warm up in idle for 5 mins?
No, it's not.
Everything else will be stone cold if you leave it idling for 5 minutes...Start it up, wait about 30 seconds, then drive off keeping the revs to a minimum, and everything (gearbox, engine, diff etc) will all warm up
wow, this goes against everything thats been told in the past, if you ask anyone they will say let your car warm up for 5 before driving, why has that been the case all these years and then someone says its bad? surely it must be better to let it idle for 5, otherwise how did everyone come to think that? im not arguing or anything, im just curious, did older cars act differently? and letting older cars warm for 5 be better than driving straight away?
if nothing else (but theres plenty else), the rich mixtures will tend to foul your plugs by idling for minutes on end while cold.
i can practically light my exhaust fumes on cold start lol. so i prefer, start, buckle up, drive off sensibly, wait till oil pressure settles to normal levels, then have fun.
Edited by Munkyb0y
I think in the old days especially if ur carby/choke was out of tune it was probly better to let it idle to warm up rather than have it stall in the middle of the road.
These days u just start up and drive light/normally until the temp is up....
why would you idle for 5 mins? The motor, if under normal mild load, will warm up faster.
if you idle for 5 mins, the gearbox oil, diff oil, all bearings etc are still stone cold.
so you think after 5 mins it's good to go? the engine maybe, but everything else is still stone cold.
best to start up, drive normally after 30s and let it all come up to temperature
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
