Does anybody know how Nissan parts treat older stock?
I am trying to get a few parts for my 240k, and i have been told that some of them should still be available from nissan.
I have an old Parts manual which gives me a part number such as 96935-R3700 (rubber gear boot insulator) I spoke to a relatively new nissan spares dealer and they said their nissan warehouse program did not recognise the part number, he tried 5 other part numbers for various parts too.
Does anybody have any insider knowledge in how i should be going about chasing up these parts? or if there are any dealers around willing to go through the pain of tracking down old bits.. or are they just not available after a certain time period (ie. they dump their old stock)
Kent
https://www.sau.com.au/forums/topic/221280-buying-old-parts-from-nissan/
Kent, Try Hornsby Nissan, or try talking to Dave at Macarthur Nissan Spare Parts, they are very helpful for me, they can tell you straight up if it exists or is obsolete or it supersedes to something else. Do you have a picture or dimensions or both, maybe we can compare the R30 bits to it.
Cheers, D
if you want I can try and look up the part in FAST. I need a VIN# and description of the part I am looking for. But on first glance the part# looks same format to current part numbers.
You could also try contacting slide or similar on the forums and see if they can source the part in japan
Hi Duncan,
thanks, but the FAST software doesn't go back to the 70's (unless you have one which does, in which case i would be greatly interested :( )
i have the physical parts manual for the car which lists the numbers, but i am not sure how nissan would advertise the superceded numbers etc.
I spend several hours looking for 70's datsun parts per week. Repco/bursons can get very basic stuff (think wheel cylinders, gasket kits etc), and that's about it. Nissan dealers have generally sucked in my experience, they seem to have a deep-seated loathing of anything more than a ten years old. I'd be combing ebay and importmonster, and join a club like the Nissan Datsun Sports Owner's Club. I can get my mitts on some second-hand 240k bits. PM me if you get really stuck, and Ill see what's in the shed for you.
I work at a nissan dealership, there are still manuals with all the parts and numbers (and crash repair catalouges) for pretty much every australian delivered datsun, including the old skylines. also can try nissan FAST, im pretty certain I saw the c210 and c110 on there last time i looked.
whether or not you can find any of the parts in stock somewhere is another thing.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
