Depending how this one went im in for the next one in 255/35/18".....
Well as it turned out the guys lost a few days un-loading with the wet weather earler in the wk & yesterday turned into tomorrow so if anyone else wants in, PM me ASAP. I'm having some issues getting a realistic freight price, if anyone has a contact I'd very much appreciate it & I'm sure everyone else wanting tyres will as well. :P
  • Replies 57
Hey John, sent you a PM the other day in regards to some semi-slicks. Did you get it?
Cheers
Hey Jeno
Yeah mate I got it, just waiting for info on semi's before I got back to you. Can you also PM me a physical addy for you, couriers can't deliver these things to PO boxes
:P
Guys I'll be back out there on Tuesday to check what's left but you NEED TO GIVE ME YOUR CONTACT NUMBERS so I can get hold of you directly. PM me ASAP.
For everyone else that have made expressions of interest, the warehouse was still a bit of a mess on Friday (~8500 tyres un-loaded last wk) so as above I'll be back out there on Tuesday. I'll PM everyone with details for payment etc & for reference, looks like I can get these shipped for $15 per tyre, to be confirmed on Tuesday as well.
PM's sent guys.
I was out there today organising some orders & I'll be back there again on Friday so that gives a few days to confirm & pay.
I can also confirm a freight price of $15 per tyre via AustPost of all places. If you're local we can sort something out at the time I'm sure :wacko:
There's also a problem with these guys bringing in new semi-slicks due to parallel-import restrictions unfortunately. Anything second-hand is open-slather but apart from the 225/45/17 RE-070's that come new on Sti's, just about every other semi they see is farked & not worth importing. I AM still looking at options, but things aren't looking too promising unfortunately.....
Street tyres are still & will always be fine, so everything's not lost. Keep the orders coming :wacko:
Hi,
I'm interested in this group buy depending how the first few go and the feedback from them,
as I have about 60-70% tread left on my tyres atm and I'll be up for a new set in about a month
mechanic recommended to swap the front tyres with the rear but as the fitments are staggered obviously can't be done
I took the sizes off my tyres;
F= 245/40 R18
R= 275/35 R18
these tyres came with the rims I bought
what's the availability of these sizes atm? as much tread left on them as possible of course :)
Yeah mate I'm sure there will be something there to suit. PM on the way.
I'm waiting for a few interstate payments to go thru & as soon as they do I'll be back at the warehouse again so if anyone else is interested, it's not too late.
PM me your details & I'll get back to you all ASAP!!
Thanx guys
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
