on a r32 gtr
hey ppl im just in the market to replace my standard R32 GTR BOV as they have shat themselves... just weighing up my options now ive got my eye on the Trust type R bov but i am going to plumb it back into the piping to avoid idle issues..... just wondering if anyone has does this and to wat dificulty? other wise ill get 2nd hand ones .. would anyone know if the r33 gtr and or the 34gtr bov will bolt up to the original pipe work?
thanks ur comments are appreciated
https://www.sau.com.au/forums/topic/221983-plumb-back-the-trust-type-r-bov/
Not sure if you are aware but the GReddy RS BOV has different diam. attachments that you can use for legal plumb backs and then a vent to atmosphere for track or spirited driving sessions :)
I wouldn't put an RS on a GTR though. too small.
Get the Type R, it won't be hard to plumb it back in. I'm pretty sure you can get an attachment for it too to plumb it in, but any competent mechanic could make one for you. The Type R is a good bov.
I was under the impression the RS was designed to flow the same as the R (race) but keep a similar size of the S (street), thus the name RS.
Having said that I know the the RS is 40mm valve size compared to that of the R's 47mm, so of course the R will support higher boost pressures (i.e. 2bar+).
I've also read unofficial statements saying that the R should only be used for applications of more than 375hp.
I guess the best thing is that they all use the same 2 bolt flange so it's very easy to change over and check the differences they make.
The type R comes in a soft and a 'hard' spring, the harder one being for cars running more then a bar. They are a good, simple piece of kit.
As for cost, you'd be better going second hand replacements imo. Type R is $200, but the kit that makes it a bolt up affair add's on top.
Edited by GeeTR
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
