hey all, just wondering r33gtr rb26, 380oddrwkw, little bit of 1/4 mile work, running max 18psi, all standard oil set up (factory pump/no aftermarket sump baffles etc, head restrictors) should i think about getting a aftermarket oil cooler?
cheers robbie
https://www.sau.com.au/forums/topic/222123-gtr-gtr-g-t-r/
Would not hurt but I see having an oil cooler will be more beneficial on a circut / drift car.
Oil cooler will just keep your oil at a lower temp so the engine will still run a lot smoother.
If you are just doing 1/4 mile work, you won't be on the track for long so there is kinda no point but if you are performing multiple drag races in one day its probley not a bad idea either IMO.
https://www.sau.com.au/forums/topic/222123-gtr-gtr-g-t-r/#findComment-3914602
and a good oil pump so the gears don't break :thumbsup:
hmmm yeah i no, it kinds sucks getting all the turbo work done, wasnt really told i should upgrade all my oil systems, well hope the engine holds till at least a year after my baby is born :blush: ha
https://www.sau.com.au/forums/topic/222123-gtr-gtr-g-t-r/#findComment-3914614
Fit the oil cooler when the oil starts getting too hot :D ...or taking a long time to dissipate after WOT.
I found a BNR32 needs to be peddled pretty hard on the street to upset oil temps.
cool, thanks, was driving up a mountain (about 10 mins) and oil temp got to about 120deg, wasnt using much boost, hate to think how hot it would have got if boosting.......
https://www.sau.com.au/forums/topic/222123-gtr-gtr-g-t-r/#findComment-3915093
120 degrees is defintely getting on the hot side.....
If you want one and have to dollars, the setups with a thermostat are the ones to go for. It lets the engine oil get up to operating temp and then keeps it there...
https://www.sau.com.au/forums/topic/222123-gtr-gtr-g-t-r/#findComment-3915754
120! Thats really quite hot...!
You dont have to have one with a thermostat, theyre often overpriced and hard to find.
The Just Jap kits are awesome, ive had one with a remote mount for a couple of years now and it does a great job. Street, track, even on a 30 degree day at winton it kept temps reasonable. And even though it doesnt have a thermostat, its doesnt over-cool the oil.
For $460 you cant go wrong.
https://www.sau.com.au/forums/topic/222123-gtr-gtr-g-t-r/#findComment-3916273
I managed to cook the oil in mine after a drive in the hills on a summers day. If you are only using the car for 1/4 mile action or a short drive every now and again I wouldn't bother. If you plan on doing track days or some extended spirited driving I'd recommend you get one.
https://www.sau.com.au/forums/topic/222123-gtr-gtr-g-t-r/#findComment-3916651
Adding an oil cooler also increases oil capacity which is never a bad thing. Especially when you dont have any other oil control mods to limit cylinder head lubrication or return. An oil cooler is an important part to any modified/hard driven car whether it be used for street, track or drags. Also in australia with our climate a thermostat for your oil isnt completely necessary as its rarely cold enough to need it.
Good luck,
Deren
https://www.sau.com.au/forums/topic/222123-gtr-gtr-g-t-r/#findComment-3918123
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
