Make: Nissan
Model: Skyline GTR
Milage: 108,000
Transmission: Manual
Colour: White
Complied? Yes
Currently registered? Yes
Price: $22,900 ono
Contact: Aku Wekara 0411880884 or [email protected]
Comments / Modifications: Below
Images: Below - more coming...
Unique GTR - Great Fun to Drive & Extremely Reliable.
Selling due to lack of time to enjoy the car.
Great condition apart from slight front bar lip damage.
1993 Skyline GTR White
108000kms Original Odometer
VIN: 6U9000BNR32301171
Fully Complied
Full 100K service done including upgraded timing belt, water pump, pulleys, tensioner, fluids, gearbox & dif oils, injectors
Dyno tuned by Matty Spry @ PITS - Safe Tune
Serviced Every 3000kms with Fully Synthetic Ester Based Oil
No Blow-By
Roll Cage
Garrett Gt2560r Turbos (Garrett -5) Only 8000kms old
3.5” Exhaust
Tomei Cam Gears
HKS Pods
Jim Berry Special Carbon Twin Plate Race Clutch - Only 4000kms old
Microtech Ltx-12 Plug & Play Ecu
Upgraded Fuel Pump
Sard Fuel Pressure Regulator
Standard 444cc Injectors (needs upgraded injectors for easy power increase)
R34 GTR 18” Wheels
Coilovers
Rear Strut Brace
Some other small suspension upgrades
Competition Brake Pads
More Pics coming soon......
$22,900 ono.
Genuine Enquiries Only Please
Located on the Gold Coast
Contact: 0411880884 or [email protected]
https://www.sau.com.au/forums/topic/222139-fs-unique-1993-r32-gtr/
umm not really but depends how keen you are to get them... id probably rather keep them as a part of the whole package type thing at the moment but if you are really keen then we may be able to arrange it... let me know.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
