latly i have seen a few videos of an R34 with underbodie aero kits installed and it has spiked my interest.i have an aftermarked front bak on my R33 so the oridginal plastic parts dont line up on anything and just flap around any way so i think ill start fabing up a template to make a front underbodie aero "guide" or whatever you want to call it.
not sure as to what ill make it out of yet but probly some sort of plastic.
opinions welcom
Jack
https://www.sau.com.au/forums/topic/222225-underbodie-aero/
opinions welcom
Jack
Hey man
I have one on my R32 that is made from 4mm sheet metal, from there it tucks up into the front bar and just screws into place where the bash plate normally is. Works a treat!!
Edited by Phils32
https://www.sau.com.au/forums/topic/222225-underbodie-aero/#findComment-3916884
Dont forget that you actually still want the air to be able to leave the engine bay from the bottom of the car, if you seal it to well it will actually create lift on teh front end and hamper your handling not help it.
that said, if done correctly it will help remove air from the engine bay causing low pressure in the bay and helping downforce (or atleast decrease lift)
use this time to seal from the front bar to your cooler, then from cooler to radiator to increase efficiency of both. also forces air the go elsewhere Ie to the sides, which will also increase the efficiency of the front end and reduce drag.
https://www.sau.com.au/forums/topic/222225-underbodie-aero/#findComment-3921044
Sasha Anis of SG Motorsport in canada did an amazing buildup of his S14 and documented his underbody aero fabrication on a forum... here's some pics to give you some ideas:
Mockup:
Fabbing:
Painted:
On the track:
Early damage:
Unfortunately the car was written off on the track and eventually parted out (think Sasha's still running a 350GT in the production class racing)... but goddamn... what a car. Should give you fellas some ideas.
It was made using honeycomb aluminium sandwiched between aluminium sheets, to reduce weight and maximise strength and rigidity.
https://www.sau.com.au/forums/topic/222225-underbodie-aero/#findComment-3921181
Shan - any pics of the front section finished?
with something that seal on the front vents out fo the engine bay into the guards would work the same as leaving vents on the underneath - 2 ducst like on the rear section on the front section would work too.
naca duct for the diff cooling is a good idea.
https://www.sau.com.au/forums/topic/222225-underbodie-aero/#findComment-3921651
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 8th February 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Thursday 6th February 8th Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and it is reccommended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs on the enty link. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
    • Just yesterday the car started to shake a bit when idle. So tomorrow ima test the some wires and packs with the multimeter and see what it is. Hopefully is a pack because thats the easiest thing to buy same day here where I live in the USA.
    • shot myself in the leg and now last night I have shaking when I idle lol
    • I'm not a big fan of the Cometic gaskets either, as above the head and deck need to be like a mirror (can't remember the RA) so Kamieri sounds like a good idea.  FWIW a mate of mine hordes old motor stuff and has some blank unground Nizmo cams for one of these in his supply if random shit if you're interested.
