Nissan claims the RB25DET to have a consumption of 9.8 l/100km... I say what a load of bullocks.
What do you guys get from a full tank, distance wise?
around 300 or 350 if granny drive haha
370km highway to a tank, thats with a rb25 with 240rwkw, running WAY too rich though I suspect, would reckon it averages out to around 12.5l/100km without driving it on boost a lot
oh and the 5 litre, well that goes from 11L/100km highway to 18-19L/100km around town (auto slushbox and aftermarket cam blah)
Edited by bozodos
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
