I dont think the front bar blends well with the lines of the car.
Cant tell if its just that photo of it, but seems to lack any fine detail on the front bar?
What kind of fine details would you like to see?
It's an aero package for racing, looks smooth and slick.. as it should.
I'm sure they'll have some bling on the road car.
Based on the 290kW, 520Nm 5.4-litre Boss 290 V8-powered Ford XR8 road-going sedan, the new FG-01 will be displayed on pit lane throughout the race and then take to the track for the assembled fans to witness its maiden run
Hahaha Thats a laugh...yeah the body shell was made in the same factory and it has 4 wheels...thats the only thing they have in common
I think they meant thats what it's styled to be like, the color, bonnet, headlights ect...it's meant to look like a race going xr8 (good marketing)
As oppossed to being built from an xr8.
But hey I could be completely off track :cheers:
Edited by madbung
I think its just a Typical motoring journo having NFI what there talking about. bit like Ch10 claiming that the V8s had 750hp and that the LS1 in the Brute series was a 350 Chev.
IMO its should have read "Based on the FG falcon" with out mentioning the Donk because it makes it sound like the V8SC is running the 32V 5.4 and not a 302 Windsor.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
