hey all i have just been researching oil restiction for this build. i have taken the following info from the major thread. info was provided by gary (sydney kid) and can be found on page 153. here it is again. hope this helps some ppl
RB26 cylinder head= 2 oil feed galleries between the block and the head
We block one off, same as RB26's are standard
We use a 1.5 mm restrictor in the other
Plenty of oil flow to the camshaft bearings, not too much oil slopping around in the head, getting chucked into the catch can and leaving the sump in short supply.
RB25 with VVT= 2 oil feed galleries between the block and the head
Plus 1 feed to the VVT actuator
Plus leave the VVT oil feed as per standard
Plenty of oil flow to the camshaft bearings and VVT actuator but not too much oil slopping around in the head, getting chucked into the catch can and leaving the sump in short supply.
RB25 without VVT= 2 oil feed galleries between the block and the head
We use a 2.0 mm restrictor in the other
Plus block off the VVT oil feed
and a couple of diagrams
http://www.skylinesaustralia.com/forums/in...st&id=26521
http://www.skylinesaustralia.com/forums/in...st&id=26522
the only question i still have that i have not been able to find an answer to is,
does it matter which gallery you restrict and which you block off??
dan
https://www.sau.com.au/forums/topic/222706-oil-restriction/
dan
I thought I was quite specific when I posted "same as RB26's are standard" ie; the front one
Cheers
Gary
https://www.sau.com.au/forums/topic/222706-oil-restriction/#findComment-3932093
  • 3 weeks later...
I ran with a single 1.5mm up front and blocked rear as suggested in the thread.
The setup seems ok and has travelled quite a few kms but from day one I was getting a little valve train noise for a fraction of a second following start up of which was not there prior.
If I were to do it again I'd probably go with leaving the std RB30 1.8mm restrictor up front.
All though I possibly believe the valve train noise was as a result of the head bloke not knowing what he was doing with the lifters as a result they trapped a little air inside.
So as they so do it right do it yourself. I've pulled the lifters apart; meticulously cleaned, primed and reassembled.
https://www.sau.com.au/forums/topic/222706-oil-restriction/#findComment-3982794
Im using th 25de (vvt). Ive been told i have two main options, one is to block the rear gallery all together but was told it can starve one end of the head during start up. Which isnt much of a trouble as it disappears once oil pressure is up but id rather go with the other option to just restrict both galleries using the tomei restrictors. Anyone else gone 4 this option?
https://www.sau.com.au/forums/topic/222706-oil-restriction/#findComment-3994028
Block the middle and use the front feed (the VCT one) and then restrict the rear feed according to the table.
Cheers
Gary
https://www.sau.com.au/forums/topic/222706-oil-restriction/#findComment-4001986
  • 4 weeks later...
I posted about this before ages ago....you can use copper mig tips...just find the size that has the correct hole diameter you want and machine it down or cut it down to suit. Pretty sure most std mig tips are around a 1/4" OD.....actually i cant recall now...maybe it was about 7mm or 5/16"...either way it works :starwars:
Edited by r33_racer
https://www.sau.com.au/forums/topic/222706-oil-restriction/#findComment-4062777
  • 5 weeks later...
I am going to be using an RB25DE head without VVT.
Could I block the rear feed and use the RB30 1.8mm front restrictor without filling the catch can with too much blow by?
Car will be used for daily duties, towing & the odd 1/4 run
https://www.sau.com.au/forums/topic/222706-oil-restriction/#findComment-4116336
You could and it would be fine.
However at this point in time, if I were to do it again I would restrict both down to 1.5mm and run a nice catch can setup that drains to the sump.
The drain to the sump also works to vent the bottom end as a result the oil is able to flow from the head back to the bottom end considerably easier.
All though mine has had no issues the top end is noticeably noisier since performing the oil restriction mod on first start up when cold.
https://www.sau.com.au/forums/topic/222706-oil-restriction/#findComment-4116417
  • 4 weeks later...
If the cold start-up noise is somehow related to the elimination of the rear feed, I can see the logic in retaining both feeds.
Here's a variation on the theme, using the idea that a single 1.5mm restrictor otherwise supplies enough volume during operation:
MIG tips are available with a 1.2mm orifice. Cross sectional area - 1.13 sq.mm
SK's preference of 1.5mm restrictor provides cross sectional area of 1.77 sq.mm
Install 1.2mm restrictor front and rear gives ~ 2.25 sq.mm so slightly more flow than 1 x 1.5 but way less than 2 x 1.8 or 2.0mm as stock. Similar end result and maybe avoid the issues Cubes identified.
Could be wide of the mark and solely related to hydraulic lifters but worth raising.
Comments?
https://www.sau.com.au/forums/topic/222706-oil-restriction/#findComment-4167913
Dale would the flow be reduced further again due to increased friction losses as a result of the smaller hole? In other words the cross sectional area is not 'directly' related to flow? i.e 2 sq.mm would not flow 2x that 1 sq.mm?
I have NFI when it comes to this but visualising flow through a smaller pipe suggests so.
A friend fitted 2 x 1.1's to his and it tapped its arse off. :S
https://www.sau.com.au/forums/topic/222706-oil-restriction/#findComment-4168291
I also have little idea of fluid dynamics, but the restrictor is just that - an orifice rather than a tube. So restriction would be causing the reduction in flow rather than friction I would think.
All the same I don't want too much in-depth analysis but threw up the idea given your start up noise. If it is lifter noise only then maybe not a problem. I've heard from more than one source that using a 10W60 oil is an important part of the equation of making this setup work optimally.
Interesting to hear that your mate with 2 x 1.1 restrictors had problems with noisy lifters.
So at the least it appears to be important to stick with SK's guide and go 1 x 1.5mm and a bung in the rear?
https://www.sau.com.au/forums/topic/222706-oil-restriction/#findComment-4168655
Well... 10w60 next oil change it is then.
I'll let you know how it goes. :/
I should mention nothings broke with a little bit of noise on start up. Its now been a year since the turbo and restrictors have gone in and travelled a good 25k. There was no real wear on the lifters etc when I pulled them out recently to drop in a new set of cams.
https://www.sau.com.au/forums/topic/222706-oil-restriction/#findComment-4168676
Sticking with the general theme of the thread, who can share experiences regarding oil pump spec and restrictor sizes regarding lifter bleed out? Clearly this relates to 30/25 with a non-Neo head.
I'd presume very few of us would be running dedicated track cars with this setup, so quiet/smooth operation is still high on the list of priorities. ie. I want to avoid bleed out due to too much reduction in oil delivery to the top end.
My setup is
25DE oil pump (stock)
non VVT head
internal oil drain-backs in head + block drilled oversize to 9.5mm
restrictors 1.6mm (F) 1.2mm ®
and (hopefully) catch can with drain-to-sump
engine speed < 7000rpm
application: road, motorkhana, club sprint
Edited by Dale FZ1
https://www.sau.com.au/forums/topic/222706-oil-restriction/#findComment-4181500
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
