hmm....another venue then? garage cafe does look ok though...
i am definitely in..regardless of location - keen on meeting u guys...hopefully, i am not the only guy with a v35 sedan on the day....
Hey Rianto, good on you for ringing around to find out at Garage Cafe. You know, just now I've realised why you said I was getting trigger happy a few posts ago, I didn't even realise that I had posted the same post twice until now, hahaha
So how about we meet at Albert Park instead? Around the pits area, there is lots of room there and hassle free parking!!! Are we alright with this or any other suggestions?
Also if you guys still wanna head down to garage cafe after that meet, it's recommended to book prior to that, as if it's more than 8 ppl it's best to book otherwise the limited 15 car space is 1st come 1st serve basis...
Garage Cafe & Bar
221 Berkeley St. Carlton
3053. VIC. Australia.
P: 03 9349 5000.
F: 03 9349 1553.
www.garagecafe.com.au
Albert Park per the rectangular parking is fine.....what time on Sat 25/7? I'll be there, but must be minimum of 4 forum members or it's not worthwhile for me to drive all the way there....
I'm interested to meet up with you guys too but unable to comfirm till later in the week ... and yes if I'm there you wouldn't be the only sedan :P
Yeah that's right Rianto, the rectangular car park is the one at the pits for the formula 1 when the race is on at Albert Park.
Great, we can meet there at the same time as specified before? 2:30pm!!!!
Time can always be changed so that we can suit as many of us as we can.
So....confirmed on Sat 25/7/09 at 2:30pm Albert Park (Rectangular Section carpar) for:
1. Me - siu_loong_bao
2. MILLOS
3. BenzLe
Maybe's:
1. Nissan_Rules
2. rs73
Anyone else? There's gotta be more Melb V35 owners out there...Gosh!
Map (from MILLOS's post)
http://www.skylinesaustralia.com/forums/po...Albert-Park.jpg
Edited by siu_loong_bao
Updated list below. Definitely worth a go this Saturday.
I don't really have a good camera, just a small Olympus digital camera.
I'm not sure how long we'll stick around for.....we'll just see how it goes, it will be our first try....we will have to do another one so that the guys/girls that cannot come this Saturday because of work or other commitments can make it.
2. MILLOS
3. BenzLe
4. pw350gt
Maybe's:
1. Nissan_Rules
2. rs73
3. scorp
Comfirmed on Sat 25/7/09 at 2:30pm Albert Park (Rectangular Section carpar) for:
1. siu_loong_bao
2. MILLOS
3. BenzLe
4. pw350gt
5. nissan_rules
Maybe's:
1. rs73
2. scorp
3. Japav
is this a guys meet or any of your partners coming as well?
... else I'll just drop off wifey in the city for her shopping or something :P
Edited by nissan rules
Mmm I was thinking that myself.
There is not much for them to do there other than admire our cars :P (I don't think they'll be interested in that though) so I was thinking not to bring my partner along.
If you guys will bring your respective partners then I might bring mine also.....Rianto, will you bring your wife and the new bub??? Imagine that, his first skyline meet, only a few days old. :D
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
