Well.....like last time, put down your name and get a running list happening.
This time, let's be more organised, can someone bring some labels? so that we can write our name and member ID...:P I am terrible with names...
Date: Saturday 5th of December
Time: 10:00am
Place: Blue Water Hand Car Wash, 468 Mt Alexander Road, Ascot Vale
Cruise: Travel to St Kilda (via Lygon Street) and cruise down Beach Road to Mordialloc.
I'll start the list:
1. MILLOS; Pablo
2. RS73, Rianto
3. siu_loong_bao, Nelson (I may skip the long cruise to Mordialloc)
4. scorp; Sam
5. missV35; Fiona
6. xscape237; Brad
7. pw350GT; Yun
8. japav;........?
9.
10.
11......and so on....
This time, let's be more organised, can someone bring some labels? so that we can write our name and member ID... :down: I am terrible with names...
Time: 10:00am
1. MILLOS; Pablo
2. RS73, Rianto
4. scorp; Sam
5. missV35; Fiona
6. xscape237; Brad
7. pw350GT; Yun
8. japav;........?
9.
10.
i wished i could make it this time, leaving for o/seas on the 3rd... bugger!
wish you all a good and fun day... GL
That's a shame Edwin, maybe next time. I'm sure we'll try and organise another cruise in the not too distant future. When are you back? Where are you going?
Nelson, I can get my hand on blank labels that we can use as name tags.
yeah! and I'll make sure I can make it! lol
I'll be back on the 1st week of Jan. visiting Philippines!
i think benny boy is really not coming becos of all the sh*t we gave him about his interior....lol
congrats on the baby...seems like heaps of people are due for a baby (or have had a baby this year).....or is it just becos most people that i know are getting old??? lol.....
second one for sure....
face it, Nelson, you're not getting any younger.
Congrats millos... lots of hard work I tell you... you'll never be prepared enough till it hits you right in the face...
It was rs73 who had to spill the beans! Enjoy the meet and look forward to seeing some photos! :P
This time, let's be more organised, can someone bring some labels? so that we can write our name and member ID... I am terrible with names...
LOL. mate, No need for the stickers for you. just bring a dozen of "siu long bao" so they can share after coffee. LOL. in that case everyone know you.
[quote name='rs73' date='4 Nov 2009, 10:56 PM' post='4918348'
I'm not the one having the baby, it's Benny!!! Interior Benny!!!
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
