I'm in the midst of designing a fuel set-up for our R33 and I'm keen to get some ideas on what other people have done.
For reference I'm working with
- Surge tank with dash fittings
- Boch 044 Fuel Pump
- Bosch Fuel Filter or Earls Fuel Fitler
And looking to make a boot enclosure to (reduce noise and spill containment) with teflon lines to reduce fumes.
Here are a few pictures I have collected over time from the forums.
For those with hard line setups, what have these costed you?
https://www.sau.com.au/forums/topic/222875-fuel-system/
  • Replies 68
Posted Images
here's mine
i think all those set up u got are way too complicated and takes up too much space.
i dont like the hard lines because it's always there...i used soft lines because it's hideable.
set up:
-3 HKS 280L pumps
-2 aeromotive fuel filters
-aeromotive fuel pressure regulator anodized in black
-defi fuel pressure guage incar
-earls fittings anodized in gold / black
-earls special black lines
-Sard twin pump surge tank
here are photos
Edited by felixy69
https://www.sau.com.au/forums/topic/222875-fuel-system/#findComment-3927767
The hard lines do help with fumes, although braided lines would help remove some of the noise from hard lines vibrating too. So I guess it depends on your situation.
I would have thought 3 fuel pumps was complicated :thumbsup: compared to a big single
https://www.sau.com.au/forums/topic/222875-fuel-system/#findComment-3927784
Have recently completed my surge tank setup with teflon braid, 044 and low pressure (pump suction side) filter. No smell, easy to set-up but was very far from economical. Prob over 500 in fittings, plus tank, pump and the filter was 150odd. Im about to re do it with a second 044 now im running out of fuel and will be doing it all with hard lines, not only for cost but imo it looks much neater and I will be taking the opportunity to replace the old fuel lines under the car with new ally hard line also (the line itself is dirt cheap).
https://www.sau.com.au/forums/topic/222875-fuel-system/#findComment-3927785
This is my fuel setup in the engine bay too, obviously still got a fair bit of work to do.
felixy69 - Nice work on the electrical switch in the rear windscreen too.
DCIEVE - If your changing to hard lines you will be buying all new connectors, wouldn't it be cheaper and yet still effective to just add the other 044 with braided lines, utilising a Y junction?
https://www.sau.com.au/forums/topic/222875-fuel-system/#findComment-3927804
Not sure what you've done with your fuel setup in that pic though?? Looks like you've gone single feed and twin return.... I'd be splitting the feed to both ends of the rail and returning to the reg in the middle like felixy has shown in his pics.
https://www.sau.com.au/forums/topic/222875-fuel-system/#findComment-3927818
Single entry in the middle with the ends feeding to the fuel reg, with the bottom of the fuel reg being the return line.
https://www.sau.com.au/forums/topic/222875-fuel-system/#findComment-3927821
Bosch 044 mounted in tank. No surge tank. No smell. No noise. No Surge either.
Looks stock, sounds stock, and has no legality issues.
Have you done any serious track work with the car? I would think that hard braking and/or cornering might give you pickup problems.
But once again it depends on the intended use of the car. I chose a surge tank because I'm keen to get involved with some time attacks and for the sake of $100 a surge tank is really not that expensive.
https://www.sau.com.au/forums/topic/222875-fuel-system/#findComment-3927825
PSI where did you get that fuel rail?
Im looking at doing a megga fuel system upgrade soon and chasing a top feed rail for when I change them plenum.
Keep the pics coming guys, Its giving me Ideas :thumbsup:
https://www.sau.com.au/forums/topic/222875-fuel-system/#findComment-3927842
It's a standard GReddy item, Part Number #13920606
There are two versions however, one for use with the GReddy Plenum (11mm #13920606) and a generic one for top feed injectors (10.5mm #13920605).
Both come with earls fittings (as do all trust products like catch cans, etc.)
https://www.sau.com.au/forums/topic/222875-fuel-system/#findComment-3927854
Not tracked it yet with this new setup.
Pushed it hard under brakes/throttle, and through some corners. No surge...
But I'm also not stupid, the tank holds 65 litres, I won't let it drop below having 50litres, at a time to refill. When pushing, don't do it with less then 35 litres in there.
Factory fuel tank is designed with a swirl/surge point in the pickup. Just checkout the design of the factory tank.
https://www.sau.com.au/forums/topic/222875-fuel-system/#findComment-3927883
The only problem is that with any track work you would want to remove as much weight as possible, i.e. only as much fuel that is necessary to get the job done. Which would quite often require you to go below that 35 litres. At the end of the day it's horses for courses. Everyone has a different set-up as everyone usually has different budgets, goals, hp figures etc.
https://www.sau.com.au/forums/topic/222875-fuel-system/#findComment-3927921
If I were racing. Weight is an issue, yes.
Doing it my own way for time. I'll leave it how it is.
Even dropping the 20 - 30 litres out of the tank for a "race" I'm only looking to save 10KG really... Think about it, you add a heap more weight back in with extra tanks, pumps, wiring, fuel lines, etc etc...
If I were racing, and going for every hundredth of a second, I'd have a completely stripped out car. On a car like ours, with full interiors, 20 - 30KG is NOTHING. Especially when you have to start dealing with legalities for road use.
https://www.sau.com.au/forums/topic/222875-fuel-system/#findComment-3927975
Don't get me wrong, I wasn't having a go at your set-up I was just pointing out that your particular setup is probably not ideal for circuit use, which is what I'll be targeting this setup for :)
https://www.sau.com.au/forums/topic/222875-fuel-system/#findComment-3927997
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
