It really comes down to who is tuning the car. Make sure your tuner is comfortable and very familiar with the ECU.
Personally I like the Autronic. As good as a Motec, but without the huge price tag and 'pay more for more features' bullshit. Autronic has everything available from the get-go.
Will the Microtech work with Nissan sensors, CAS, etc?
Like I said, 'Plug and play' lol........ just needs a vac/boost line from after the throttle body.
the thing about the individual throttles and the map sensor is that you need a vac line from after each throttle that then goes into one line.......
thats my understanding anyway (at least to get a good stable reading - you could grab it off one, then use a multiplication factor or something, but it never would be as right as a line from after each throttle)
if you havent yet, have a gander at this site
http://v8soarer.com/itb/index.shtml
guy did ITB's for his v8 soarer............
Yip, Toyota has the same on their itb's. I'll be running a vac line from each one for the MAP.
For the brake vacuum boost I'm going to fit a diesel Navara alternator. They run a small compressor off the back of them for the brake booster. :dry:
Interesting project, keen to see how it turns out. Certainly an unorthodox approach, especially given the car's purpose in life, but I wager you're a better judge of that than some bloke across the tasman on a computer!
Triple 2 barrel side draught setup on a S20 motor -
http://www.datsunhistory.com/skylineeng.jpg
Thats an L-series six old mate, only one cam there!
Edited by floody
Personally i would be steering clear of the Microtech. I ran an earlier LT8 on my old RB20, ok not an LT12 and they were a bit crude in the fuelling dept. They were also very sensitive to voltage, which is still a common problem based on some cars i see running the LT12.
After a lot of time and effort tuning i was finally able to get some reasonable control of fuel, and on an NA car you want the fuelling spot on to give you that sharp throttle response.
I know it wil partly kill the sound, but have you considered a big fibreglass airbox for the inelt setup? Filtration will be easier to sort, an important thing for rally car. You can also throw a an AFM on the front of it after the air filter panel. I have seen similar setups on several 80s rally cars running injection. It also means you can run the std ecy re-mapped to your needs.
I love what you are doing, every time i service for a friend i sit in the bush listening to all the cars coming through and dream of building a basic NA RB20 GTSt rally car. The sound of the RB20 through the bush would be awesome.... :)
Its a bit late..
But my old man just pick up a 26 intake manifold for his 25det. I been looking.. could custom trumpets just be slapped up to ITB's on a 26 manifold?
Because then you can mate to the head.. TPS is sorted.. etc
Edited by GTS4WD
26 intake with the 4age throttles? Could work. Mate of mine works in the CNC machining industry, so I've just given him another homer to do.
We're going to dummy up some runners next week and see what we can make fit.
a guy i know has fabricated plates to adapt the RB26 throttle bodies onto the RB25 head... let me know if you are keen and i can put you in touch with him. actually i think he has a thread floating around here somewhere
Hmm, got a small problem with the itb's. The Toyota factory spacing is too different to the head ports on the RB. I was just going to take up the difference by using the intake runners to line them up but now we've got it in bits I don't have enough length to do so.
So now the linkages between the itb's need to be modified and a new flange made to suit. No biggy, we'll get there...
Here's a pic of the smelly old head and ports. Will be good to see a nice shiney head in it's place.
  • 4 weeks later...
Also...
5 out of 6 fit!
Link ECU will be here in a day or two and the car is getting shipped back to the workshop where we can start:
Building the head
Re-plumb the coolant lines from the head.
Re-plumb the clutch master cylinder (that's why #6 don't fit)
Remove HICAS servo thingy
Wire in Toyota TPS
Plumb in MAP sensor
Move battery
Make new throttle cable
radiator
fan...
Oh god that's getting depressing!
Looking awesome mate!!
Roy: Microtechs were our ecu of choice, when wired up properly we rarely had any dramas with them, they have come along way in recent times, and for sheer bang for your buck i dont believe you can go past them for a full stand alone ecu once people get there head around the fact that not being plug and play for all applications isnt such a big deal. Customer service on the otherhand could do with some improvement.
Now that the ITB's are built and the dummy fitment has been carried out, we can get stuck in and remove all the stuff we no longer need, to make way for what we want.
Flicked out the radiator and took the stock head off the other afternoon.
Now we can look into all the plumbing adjustments and flick some paint on the red bits.
My G4 Link ECU has turned up now too, so most of the bits I need to make it run are here.
  • 3 weeks later...
Yeah we're getting there slowly. We're all too busy to spend much time on it.
The engine bay has been cleaned and painted, I've re-plumbed the powersteering and removed the redundant HICAS pipes also.
I've prepped the block and should be fitting the head this week.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
