  • Replies 461
Posted Images
Wasn't WA Susp that paid for it,
Matel are picking up the tab...
You know the guys that have commissioned an action figure based on the awesomeness of Mike's fighting prowess on the Battlefield, the Bar,The Dance Floor and the Karting Track!
G.I Mike The Greatest Hero Of Them All!
ahh didn't you hear
Mattel has issued a recall on the G.I. Mike something about it not saying on the box that it is not for children under 12 years as it contains SMALL PARTS
Nice one.... But I know it is small....
I also know it works (1 X Man Cub)
It is my weight saving committment to the Karting Day for Team RamRod!
this is true at least we know you are not shooting blanks
Trying to make him think that I care.... Which I don't
Hoping he (Mattley) will believe that I / We are going to take it easy on him instead of handing out a massive reaming..... Oh and then beating him on the track!!!!
Mike/Bard - you had better go practise this weekend or come and injur me, or both... I have just printed up team Green Wang Pump Racing decals and they will surely add 3-4Hp to the engine and vastly improve aero... I also boooked into the local GP to remove one of my balls cos its only going to take half a man to beat you guys... it is also saving me at least 6kg of balast!
* Sneak into Scotty's bedroom, opens smelling salts and snaps fingers....
"Wakey Wakey Scotty,
Your dreaming again.....
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
