My Ceffy... friend of mines Charade too. :D Yes its a chick... lol. Love this picture...
Love this one too!
Mate of mines 180sx too. :P
I took this picture up in the hills when the sun was setting, it came out remarkably well! Had perfect tone on it, one of the best logo pictures you could get on a car IMO. :whistling:
Still have work to be done obviously
Only one of the couple photos Ive taken off my unfinished ride
Oh and that Ceffy looks sick near the Woolsheds, was gonna get some nice pics of mine there when it was done
i agree! top pics there coysey (adman)
iv always wanted to go get some photo's down ther in port adel. theres something about those woolsheds that
tickles my fancy.....not in a weird way.
nice photo's people!
well its about time u upload mine me thinks...
i know its not a skyline, but its my ols stato, and i love the way this pic turned out
Now for my 33, this is how it was the day i got her
And these are the current pics, with new 19s, cut bar, painted FM etc
i couldnt resist putting this vid up, its the biggest flamage i have ever had lol thanks to flick for taping :D
>> clicky <<
:rofl:
Edited by craig R33
Looks good craig
Im going a similiar approach to you
I took my rear wing of and am contemplating if I should get the holes bogged up and repainted boot (wingless) probly will
And am lookin for some 19's, i got a series 2 bar today so my cars going to get the boot and bar done 2moro :D
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
