My Ceffy... friend of mines Charade too. :D Yes its a chick... lol. Love this picture...
Love this one too!
Mate of mines 180sx too. :P
I took this picture up in the hills when the sun was setting, it came out remarkably well! Had perfect tone on it, one of the best logo pictures you could get on a car IMO. :whistling:
Still have work to be done obviously
Only one of the couple photos Ive taken off my unfinished ride
Oh and that Ceffy looks sick near the Woolsheds, was gonna get some nice pics of mine there when it was done
i agree! top pics there coysey (adman)
iv always wanted to go get some photo's down ther in port adel. theres something about those woolsheds that
tickles my fancy.....not in a weird way.
nice photo's people!
well its about time u upload mine me thinks...
i know its not a skyline, but its my ols stato, and i love the way this pic turned out
Now for my 33, this is how it was the day i got her
And these are the current pics, with new 19s, cut bar, painted FM etc
i couldnt resist putting this vid up, its the biggest flamage i have ever had lol thanks to flick for taping :D
>> clicky <<
:rofl:
Edited by craig R33
Looks good craig
Im going a similiar approach to you
I took my rear wing of and am contemplating if I should get the holes bogged up and repainted boot (wingless) probly will
And am lookin for some 19's, i got a series 2 bar today so my cars going to get the boot and bar done 2moro :D
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
