vu, iv said it once mate, and ill say it again.
fan-fuukin-tastic!
love it.
you take good photos vu, we should get together sometime :blink:
His car makes the photo, any other car would ruin it.
jelous of that front bar vu.
if i had a series2, i'd steal it from you
Cheers guys! :blink:
  • 8 months later...
Just went through 16 pages of nice looking cars guys,
One question; Dohmar how come the front bar lip was removed since you bought the car off writeoff? Its begging for it man looks incomplete without it. New ones from NissanJapan are $550 which isn't too bad
I have a few favourite photos of my own car, only thing that has really changed is the plates, which are CC **** plates now, Square rear slimline front.
My old car I miss...
dont really have a fav as the car keeps changing but heres some i like anyways
and this is the latest pic i got (couple weeks old) with m type skirts on
Edited by SkyHi_33
a) because the car is lowered and the front lip crashes against everything, b) the front lip doesnt look all that great imho, and c) if you bothered to look at your car side on, you'd notice that removing the lip makes the front spoiler level with the skirts and the rear, as it should be. putting the lip on looks like a train with a cow scoop, unless you have the car at standard or above height and are running the bigger skirts and rear bar. which i decline to do because the gtr looks good enough as it is.
answered?
I still have the lip. I choose to have it off.
-D
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
