vu, iv said it once mate, and ill say it again.
fan-fuukin-tastic!
love it.
you take good photos vu, we should get together sometime :blink:
His car makes the photo, any other car would ruin it.
jelous of that front bar vu.
if i had a series2, i'd steal it from you
Cheers guys! :blink:
  • 8 months later...
Just went through 16 pages of nice looking cars guys,
One question; Dohmar how come the front bar lip was removed since you bought the car off writeoff? Its begging for it man looks incomplete without it. New ones from NissanJapan are $550 which isn't too bad
I have a few favourite photos of my own car, only thing that has really changed is the plates, which are CC **** plates now, Square rear slimline front.
My old car I miss...
dont really have a fav as the car keeps changing but heres some i like anyways
and this is the latest pic i got (couple weeks old) with m type skirts on
Edited by SkyHi_33
a) because the car is lowered and the front lip crashes against everything, b) the front lip doesnt look all that great imho, and c) if you bothered to look at your car side on, you'd notice that removing the lip makes the front spoiler level with the skirts and the rear, as it should be. putting the lip on looks like a train with a cow scoop, unless you have the car at standard or above height and are running the bigger skirts and rear bar. which i decline to do because the gtr looks good enough as it is.
answered?
I still have the lip. I choose to have it off.
-D
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
