1x large permapine post, 1x guard rail and various little white reflective posts. I've had it for no more than a month :kiss:
LOL sounds like your enjoying it. Still feel all alien to be sliding or getting back into the swing of things now?
Man, I want a slider.... Someone buy my GT-R :D. Would have been good to see some before shots of the damage lol
Edited by Weezy
learn how to drive will ya :)
Nah.
Deej.
Man, I want a slider.... Someone buy my GT-R :) . Would have been good to see some before shots of the damage lol
Surprisingly had no trouble getting back into the groove. After 7 months I was expecting to be super shit but hit up a few corners in the dry and it all came flooding back. Throw in some rain and its linking corners in 3rd :blink:
This is how it looked before I really got into skidding it
Edited by AndrewJZX100
Yep love the GT-Cs on your GTR!!! I nearly bought some for the 35 from JIS, but they had about +10 less offset then I wanted :blink: (and really were more than I wanted to spend for a daily)
but got these instead :)
18 x 10 +24 on the rear - won't fit under your guards mate - not even close :blink: Perfect for my car though. Shame the fronts are 9 x 24 - not even close to tuff enough for my car. In fact my 9.5 +20s are only just ok for the front, but leave the rears on my car lacking. I am going to put 20mm bolt-on spacers on the 35 for the Kadina show - so they will be 9.5 +0 on the rear :)
18 x 10 +24 on the rear - won't fit under your guards mate - not even close :thumbsup: Perfect for my car though. Shame the fronts are 9 x 24 - not even close to tuff enough for my car. In fact my 9.5 +20s are only just ok for the front, but leave the rears on my car lacking. I am going to put 20mm bolt-on spacers on the 35 for the Kadina show - so they will be 9.5 +0 on the rear :nyaanyaa:
I was looking to get 18 x 9 at the front with a + 18.......and 18 x 10 at the rears + 22
so only a trail fit away now :)
should be fun.
this an 18 x 10 +12 on the 14.
Edited by scandyflick
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
