Wouldnt say favorite but its the first time shes ventured in to the sun since this time last year and i fell in love again :wub: haha, its my dysfunctional creation of monstrosity
Still got loads of body work, sealed under body, diffusers, and a more practical selection in wheels/tyres for time attack but its getting there... dont judge it too much just yet :P
I pick up the engine in the next day or two, its been in storage for along time. has a big single and last time it was together had 512kw. it doesn't have the wide body, but i was thinking about putting every thing off this car on a GTST shell, with the wide body (Veilside GTR is uncomplied).
Ever herd of endless racing? its embossed on the front bar and the was a badge on the boot?
Endless is a famous japanese tuner company best known for their brakes and braking components... Now that you mention it its also painted the same colour as the brand...
Maybe an endless demo car of some sort from the past?
Ahh the Ace of Spades. Lemmy would be proud!
-D
the build some crazy drag cars :woot:
here is a pic my brother took at the last drift prac, noticed my number plate light isn't working and in a video he took you can see it turn on and off every time i hit a bump :laugh:
^Spot on Lukey! Marko they are a different tuning company Not the brake manufacturer by a similar name.
They sure build some tuff cars... Heres a couple from Osaka Automesse in '09:
post-27804-0-54177700-1318421743_thumb.jpgpost-27804-0-90565600-1318421792_thumb.jpgpost-27804-0-30725400-1318422033_thumb.jpgpost-27804-0-15081300-1318422083_thumb.jpgpost-27804-0-60528700-1318422115_thumb.jpg
Definitely learn something new every day haha, love the demo cars there, looks like some serious bit of gear! But then again... should i expect anything less haha.
Those cars look amazing. Would love to see the 32 on the track :D
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
