hi guys,
im getting the trust/greddy timing belt kit which includes the seals & bearings...has anyone changed their timing belt themselves on a gtr???
ive been contemplating whether i do this myself or not, ive changed timing belts & timing chains on my previous cars which was simple (make it top dead centre etc) but not sure if i should do this myself being a gtr - am i going to run into any problems if i do this? im assuming the crank bolt will be super tight - im also guessing the radiator etc needs to come out for accessibility.
ive got the workshop manual to check tolerances, torque wrench & other tools required.
i also had it tuned so im worried that the CAS might be out when i put this back on, can i just mark it with pen & put it back in position??? will the new belt also change my cam timing??? last thing i want to do is destroy my tune after spending a good amount to get this right but if its as simple as swapping over the belt & putting the CAS back in the same position im happy to give it a go :P
thanks guys,
https://www.sau.com.au/forums/topic/223955-changing-timing-belt-on-r32gtr/
the cas is easy, if its never been touched before, when you undo it you'll be able to see where the bolt was originally, otherwise just mark it with a permenant marker or white out if you're worried.
The crank bolt will be very very tight, but you will also need a harmonic balancer puller because its pressed on, other than that everything pretty straight foward if you're good with turning spanners. If it was me, i would also replace the water pump while everything is undone.
Just remember make sure everything is absolutely spot on with the belt, these arent a free running engine, the valves and pistons WILL HIT if it jumps too many teeth.
Goodluck
hi guys,
thanks guys,
im still not sure if i do this myself - anyone here done this themselves? i do need to make a harmonic balance puller
hi marko just get the thingy and turn that over, move the whatsy to the left, fill the jibbtipop with the best you can find,don't for get to take a break buy the best meat pie you can get have a vb for strengh and a power nap then get to it again with a long look a phone call and a scratch of the head then put it together again and give us a call when the tow truck comes to pick it up.....................take it to Mr it will be all right and tell him to set it up the same as he took it off or if your worried take it to Mr personality.
LOL - nothin like a "Fourn Twenty" & Vitamin B, they dont know what they're missing out on!
mr 'dont worry about it' is doing it for me
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
