Despite doing some good 'business' out of my boot yesterday... I still have 14 shirts left!
If you ordered one - can you please reply here and let me know:
1. have you got your shirt
2. have you paid for your shirt
I'd just like to do a complete stock check and get shirts out to those who ordered them ASAP - it must be cold without them.
There are some spares too - just not 100% on what sizes...
Cheers
James
https://www.sau.com.au/forums/topic/22407-t-shirt-stock-take/
Funky: Are you at work? I have to drop of something at the airport so can pop back through the city if you like?
9.00pm now - will be coming back about 10.00pm? Will give you a call when on my way.
Ok - looking good...
I just need confirmations from:
Ronin09, alinche, cooks44, Scorp, Shiro, MaXiMuS007, quickshift and andzmax
Have you got your shirts yet?
Do you still want them (Quickshift, Adzmax, Scorp, Shiro & Max are noted as not payed yet)?
Once this is cleared up - I'll go through the spares on a first-come, first-served basis. Will keep you informed...
Dox: Great - thanks :)
Here are the current stocks.
If you are grey - you have paid for, and collected your shirt. And are happy :D
If you are green, you have paid for - but not collected your shirt.
If you are purple, you have not collected or paid yet.
Pink rectangles are spares.
Please correct me if I've gotten anything wrong.
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
