hey guys got my turbo put on, all tuned on 16.5 psi running 251rwk with all supporting mods.
the turbo does hold boost but as soon as u hit 5,000rpm it just hesitates and drops off to 5 psi. can hear a hiss but cant find it.
took my car for a drive tonight and didnt feel as strong at higher rpm.
boosted it again and it got way worse. in 3rd gear soon as i hit full boost car feels like the brakes are being applied and wont rev anymore.
the first couple of times when its just warming up is fine then it does it. boost was dropping down to 4-5 psi.
turbo is new. checked all my hoses and inspected the turbo and its perfect still.
only thing i can think of what i did last week i wasnt paying attention and i ran up a rounded gutter and cracked my front bar. been doing it since then. few days ago
Edited by R33GOD
https://www.sau.com.au/forums/topic/224398-need-help-r33-gtst-related/
i have a blitz bov. its atmo
these are my mods
stock internals
hiflowed ball bearing turbo 450hp
splitfires
pfc
blitz fmic
tomei pump
600cc injectors
z32afm
stock intake pipe with k&n air panel filter
full 3in exhaust.
hid boost controller
Edited by R33GOD
have you checked all your pipework? sounds like a leak from something.... try getting under the hood and flicking the throttle cable see if you can hear where the leaks coming from.... as for the car feeling like the brakes have been applied that souds like saftey mode so you dont blow it up....
ok fixed the hose problem but it still drops off boost sometimes.
it only does it when its been thrashed after about 6 times or so.
spoke to my tuner and he thinks it could be my hdi boost controller solenoid getting way too hot. or an actuator issue?
thoughts and experiences if anyones had a ebc prob or actuator prob?
today i further inspected the problem and still couldnt find the prob.
so far i have done a boost leak test.
changed boost controllers
took off front bar inspected cooler and silicon piping
changed all boost line hoses from actuator.
only thing i can think of is maybe the intake pipe is sucking closed.
cause it only does it when u hit the throttle hard on down gear, or at top end as i change hard into 4th. and sometimes 3rd
Edited by R33GOD
it does sound like a boost leak coz at high rpm it drops but if it was it would have given way and popped off hope u work it out! Try connecting a hose straight from the wastegate to the intercooler piping and see what it does then?
ive done everything and soon as the car gets hot after a couple of runs its still doing it.
i done rev210's intake pipe mod also, so i dont know what to do.
only thing i can think of is not enough preload on the actuator. its set to half a hole at the moment.
another theory. if i have faulty plugs and when the car gets real hot would it cause less combustion thus the major boost drop?
mate i had simular prob wif my gtr first noticed it on a trip to melb hit full boost than dropped to half and it would only half boost up after that untill i restarted the car then it was normal again its happined about 3 times now but they have been on really hot days so i just thought it was the ecu in safe mode or something
I'd be doing another boost leak test - if you ran up a gutter and cracked your front bar youve proabbly done somthing to your FMIC or piping. Stick a can of baked beans in the intake and pump it up with an air compressor. make sure you go under the car to listen for leaks too.
ive taken the fmic out completely and inspected the piping and tanks. they are perfect
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
