  • Replies 347
Originally posted by RB20LagWagon
And i think mine is the fastest on this board
12.79 @ 110mph with 1.9 60 foot done at kwinanna with a few people from this board as witness.
*nods* I saw that run! what did ya call it sean, a "one clutch wonder" pretty amazing nevertheless :D
hey dudes
my time of 13.02 was done on the road with an Apexi Speed Meter. Since then I have cracked a 12.94
If you want to remove me because I dont have a time slip then thats fine (i dont know how accurate it is)
what about G-tech? only joking mate :D
I have recorded a 1/4 mile time at Heathcote but was in the wet and looking forward to going back to the track real soon - to see what my baby can do [34 GTT]. Hoping for a high 13, similar to Franks. Based on my TS of 100mph it should be possible after looking at all the times above :P
Great Thread BTW!
OK, i accept that my R33 wont go on your list 'cause its not a street car anymore( even with a 9.45 on street tyres & street registered at the time!)
But i did a 12.1 @ 115mph with 1.8 60' on the 7/7/2002, in my almost stock R34 GTR. On pulp with normal street tyres, & i do drive it regularly in the hills. I think the R34 list should be expanded to include this.
I wont be at Jamboree this Sept with the R33 'cause we are still finishing the upgrades, but should be ready for Drag Combat in Sydney.In the meantime my 'other' R33 is still getting upgrades( or downgrades in this case) to make it more streetable with a single turbo & should be running in the mid tens when its finished.
GTRs.............. gotta love em.
Munro.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
