NIZR34GTT:
I managed a 14.7 in the wet at heathcote a few months ago, I am going back in a couple of weeks to have a proper go. My mods were: 3.5inch cat back, pod filter and approx 11-12psi.
A slightly modded 34 GTt should be able to get into the 13's I reckon - a high 13 that is :( My 60ft time was like 2.7secs and had heaps of wheelspin :burnout: even in 3rd [wet track didnt help really].
  • Replies 347
hay guys, wet33 here, to prove my 12.4 @ 111mph me and the car where in the latest dragstar australia mag there is a pic of the car at the start of the burnout. fuel pump faild last weekend so now we going all out with the fuel system, and we also putting a reverse pattern c4 auto in th girl, 4000rpm stall converter, with trans break, we hoping 4 flat 12's
hmmmm... shall i go for slowest overall? :D
before i modified mine it ran a 15.048 96MPH 60ft = 2.360 on a wet track. (almost a year ago rofl)
will be taking it back to calder next week now that ive done a few things to it to see what i can get... should be a bit more respectable :D
rofl i did a search for the same trap speed and people with less were running much faster! lol
wonder if the 40degree day and wet strip made a diff.... shouldnt make that bigger diff should it... mind u their 60ft times are damn near half mine lol
i think i need to learn to change gears properly :(
Thought I would just add that my Terminal Speed, which was 101mph, indicates my 34 should be in the same ET bracket as Franks' 13.8 sec 1/4...(2.1 60ft, 99mph)
That should hopefully make it look a bit better :(
Anyways...going to heathcote on Sunday [oct 5th] and hopefully will be recording a time in the 34 GTT category :D
Originally posted by nismoR34
I managed a 14.7 in the wet at heathcote a few months ago. My mods were: 3.5inch cat back, pod filter and approx 11-12psi.
...my 60ft time was like 2.7secs and had heaps of wheelspin :burnout: even in 3rd [wet track didnt help really].
all excuses aside u r a shit house driver aint u?? :uh-huh:
:bahaha:
:bahaha:
compared to u im possum bourne... well only going on the fact i remember ur first run at calder and u getting some pretty high times for a modified RB25DET :)
yeah thats right back in ur corner :):D
Guest INASNT
u were never there for my first run at calder when i did a best of 14.2@98MPH with a safc and exhaust!
corner?? i was never in it!!
:shake:
You should fair dinkum become a clairvoyant :D
benm update my dismal time please. I ran 13.8312 @ 101.50mph 60ft 2.2039 at Heathcote on Sunday :D
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
