Hey mate, im after 4 tyres 225/40/18. tyres are currently kumho ectas. dont mind them. what else you got similiar or better
cheapest to max about $230.
Cheers
  • Replies 175
Hi how much for kumho ku31 in 255/40/17 and 235/45/17
pm sent
Cheers
similar i have the new achilles pattern atr sport $140.
I have BFG for $160, and if you want better i have goodyear for $190
thanks mate, can i also get a price for the kumho spt ku31 225/40/18
dont have these right now, if ordered they are about 180 each...
Hey mate,
Just wondering best semi's for my wheels...
Last semi's I had were R888's on my r33 gtst rims (225 - 45 - 16)...lasted quite a few days and I got them cheap- about 170 each - do you have anything similar?
Feel free to pm me :D
Cheers,
Chris
also - could get 1 person also for a set - so would be looking at 8 tyres - good deals? :devil:
Cheers!
Hey mate,
Cheers,
Chris
also - could get 1 person also for a set - so would be looking at 8 tyres - good deals? :worship:
Cheers!
Pm sent Chris
yes im looking for similar, i have 235/45 r17's on the front and 245/45/r17's on the back i dont know much about how the wheels and tyres work but what are some good gripping tyres for street and circit and do i have to stick with these sizes or can i make them all 245/45's?
prices would be good to
cheers
what high performance 235/40/ 17 do you have
BS potenza re750, these are now on special $150
cheers
You dont have to stick to that, but i wouldnt recommend a 245/45 all round on a GTST.
you could go 235/45 and 255/40 which is pretty popular on these cars, or stick to the 245 on the rears...
have a look at what other users are trying out, as every person will have their own preferences, some like them big at the rear, some like them same size all round...
good tyres go for roughly 170 per corner, thats top japanese brands, but do some research into what suits you best and i can give you a more accurate price.
hi mate,
i'm after a quote on 4 r888's 235/45-17 fitted. Probably in the med/hard which from memory is the GGG?
cheers
Dave
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
