  • Replies 53
I'm just taking it slow at the moment. I'm waiting for the gearbox to get back to my mechanics and hopefully the thing is still broken down so I can get some pictures and then I'll talk to the gearbox specialist that diagnosed the problem so I can get specifics and also a quote on how much it would be to fix, I won't pay to fix but just so they can see how much damage is present with a monetary value.
I'm also looking into the department of fair trading but I'm a bit weary of my chances as this has been an ongoing problem for months now. Starting with them not sending the parts actually needed to fit the gearbox and due to some of the parts being sourced from Nissan it took time for them to arrive.
In a nut shell I want to know exacts and get them on paper so I can start building a strong arguement and not go into this umming and arring.
Thanks for your support guys, it's heartbreaking when you try to do the right thing by people and be nice and they just spit in your face.
just out of interest many eons age i organised a reco auto box for my mum's car
came to $500 for the box
installed but there was an issue
got them to drive the car to one of their service agents and they sorted it out
lasted for years until we traded the car in
thing is the gearbox place was not a JAP import type place so they're a bit more legit
Guys,
we all know who this business is.
They are well known for their rediculous prices, i dont even call them anymore when i need parts even though they are local to me.
Good luck with it mate, i hope you get your refund.
My gearbox never saw the road, my car has been on a hoist since last November getting work done to it but to be more precise It's been on a hoist since April just for a box that would work to go into it. This business thinks I'm doing the dodgey on him.... How the fek would I do the dodgey when my PFC is still sitting on my mechanics shelves unopened haha... The car can't even be turned on and I'm supposedly doing shonkeys?!!? Cause people love to walk everywhere so they can go to the hassle I am right now
I think my correct avenue will be the department of fair trading just need to get some particulars from my mechanic and I definitely need this digi photos of the sort of damage it's in because that will be a good indication of how severe the damage is and then I can post them up on here and see what people think.
It's the forum rules that we can't publicly bad mouth business to avoid litigation against our beloved SAU. Wouldn't want to see this place get shut down all over a silly gearbox would we? :laugh:
So who is it?
Can we all stop being pansies with the PM's..?
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
