I changed oil at 5000km's. The Motul was used in exactly the same style and km's of driving.
At first I didn't believe it so I repeated the test with the shell and again sludge in the oil filter.
Very interesting test. Basically, Shell sludge, Motul no sludge, Shell sludge.
Just a couple of question to clarify the test.
1. Have you noticed any sludge or vanish inside the engine before the test?
2. I assumed same type of filter throughout the test?
3. Did Shell consume more oil than Motul?
It really is rare that there is any sludgeing with a full syn oil doing 5000km. Logically, I think that what might happen could be that Shell actually was cleaning the engine better than Motul. The sludge that was trapped by the filter, was not resulted from burnt Shell but existing dirt from the engine. Helix Ultra could actually be dissolving the minor deposits built-ups.
Nevertheless, it would be good to do the test again now that you have done a few consecutive Motul. Also, Helix Ultra just recently got SM rated. If that means anything to you.
I did read this, and other post's on this topic.
This is my situation, i have a standerd rebuilt s1 rb25 (5000km old) Just did a track day. temp at track gets about 105 atm (will be sorting this out soon). sprited driving in the hills see about 90-95.
In example 2 of the above quote, it talks about oil thinning at higher themps...... i dont quite understand what im needing to use at these temps.
First of all, 90C and 105C is not that hot for racing. Most oil operating temperature are designed at 100C. Oil goes thinner when hotter, so it flows faster to bring away the heat. This is what I understand.
You just had a standard rebuilt, OEM oil spec for Skyline called for 7.5W30, it is not a problem to go to a 40 weight on track. Viscosity between the 30 and 40 are closed if the temp goes to above 105C.
I am sure you will have no problem with a Redline or 300V 40wt on track just as so many other people had done.
As for pressure on idle and through the rpm, other people here should be able to give you some numbers.
1 - The motor was built 90,000km's ago using motul and having the head off at around 70,000km's and then cams out just recently both times the head is a superclean shiny alloy look. No discolouration/browning anywhere.
The Shell stuff also made the lifters tick as it approached 5000km's mainly when warm. Dropped the Motul in and it never ticks.
2 - The same type of oil filter - K&N
3 - Definitely.. The shell used around 300-400mls over 5000km's where as the Motul doesn't use a drop well not noticeably anyway.
All good with the pressure now, but still not sure on what oil. The 90*c and 105*c is my water temp, i dont have a oil temp gauge, so i have no idea how hot the oil was.
In this case, pretty sure is the Shell then, quite disappointed. Probably some small proportion of Group III not holding up. To have 350ml over 5000km is not good.
Have you tried Mobil or Castrol products? Any feedback?
Only 'Synforce Oils" in my cars. Not only do you get asked what sort of car you have but also how many K's and what part of aus you live in. They only prescibe an oil that will suit your needs in all these catergories. oh and outside sources say you get kw gains by using it. just google it "synforce"
In an old redtop rb20 my motor drank about 500ml of shell 5w30 over 5000km, it also developed a few leaks. The consumption and leaks went away when I went to 5w40 motul 8100
Synforce oils are only a semi synthetic, sounds like their marketing worked well on you :rofl: I highly doubt it is any better then your castrol semi synthetics and Ihighly doubt it is better then the motul, mobil 1, and redline fully synthetic products. Have a read on their website.
http://www.synforce.com.au/synthetics.html
What product of theirs are you using and how much is it ?
Edited by Rolls
My mate, with a 25, not rebuilt is using a full mineral oil, "HPR ?/20 or ?/30". He also recomended "penrtie sin"
does this sound good?
any imput would be good, and also referance the ? too- 5w/20?
Read the thread.
Read the first page summary of the thread, then READ the thread (twice) and then post questions :D
Not being smart chaps, but i have read this thread......a few times. I dont understand the principals, as i said on the previous page. This is my main problem.
Acctually, never mind.
Ill chuck 8100 in and hope for the best. Lots of people seem to be running it so i'll be a sheep i supose. No idea if its right for My needs, but seing as nobody will take 2 mins to explain the principals behind choosing my oil (as i dont understand the examples on the 1st page) i'll retain my ignorance and be none the wiser.
Edited by 1SLP80
You could have stated that you couldn't understand the first page, otherwise people will assume that you have just seen the thread, made no effort to read it, and asked which oil you want to run with no information about what for.
A communication failure :D
I normally put in as much effort to replying as people put into posting, but in this case I'll provide some kind of attempt at a summary with many technical errors in it :D
Soooo, I'll try and help, I'm not an oil expert and I don't work in the industry.
Basically the higher grade the oil the better, don't even think about running grade 1 (I) or 2 (II) in a Skyline, you want to run 3 (III), 4 (IV) or 5 (V).
The best of these is V if you can afford it, it will cost more but its better or the car.
In other words, if you have plenty of $$$ buy Motul 300V or Redline.
If your not rich, then consider oils like Motul 8100, Mobil 1 or maybe even Royal Purple.
Go grade 3 if you want, but its preferable if you can go grade 4...
Viscosity is about temperature rating, my n00b explanation of this, as I'm in IT not the oil/engineering industries, is the lower number relates to how easily the oil can flow when cold.
The higher number relates to how quickly the oil will heat up and become thinner, beyond a certain temperature, I think its above 110degrees, the oil starts to thin out due to heat.
A final note is the gap between the numbers should be as small as possible, running 0w30 is better than running 10w60.
In other words, if you drive you car around a track and your running 0w30, and your oil overheats then you may want an oil cooler, and to run a higher rated oil 0w40 or similar.
If your driving purely street than go for a 0w30 or similar, a 0w40 won't hurt your car, but a lower spread is better (the thread explains why, I believe it relates to chemicals added to maintain the temperature range of the oil or something).
Re-read this part of the first post:
1) Fuel dilution (fuel blowby into oil sump effectively thin down the oil viscosity)
Thicker oil can withstand more fuel dilution then thinner oil but thicker oil also causes friction drag, slower spool, higher FC and more startup wear.
For example: If you run Penrite Sin 25 25w60 in your engine, at 10’c morning when you first crank your engine, you would have effectively run 1131cSt startup viscosity. That’s like 4.5 times thicker then Mobil 1 0w40 (248.8cSt@10’c). It’s like running grease through your engine instead of oil.
2) Engine oil temp
Higher oil temp effectively thins the oil down.
For example: Mobil 1 0w40 is 14.3cSt @ 100'c but when avg oil temp raise to 120'c, it would have thin down to 9.1cSt which mean that it is effectively a 20wt oil (you do not want to run a 20wt oil when you racing down a track, do you). So if your avg oil temp are 90’c, any 30wt oil will do as it is effectively a 40wt oil at that temperature.
The key to the correct oil viscosity depends on mostly the above 2 conditions. There is no one size fit all oil.
That's the best I can do, and there are a lot of technical errors in there, so hopefully someone can tell me whats wrong and I'll edit it when I get time :D
I missed, there is actually a question there.
On street, Mobil 1 5w30 silver bottle silver cap would be a good choice, not sure whether it will last 10KOCI, should be fine if you clock 10K within 6 months. Motul X-max 5w30 is another one that looks very good in paper. Ester based with quite recent manufacters' approvals.
On track, as mentioned, any Redline or 300V 40wt will return good results.
The cooling system does not give any specific numerical indication of engine temp. So it does really tell how hot the engine is running. Even the engine itself has some parts that runs hotter than another.
Hands up for all the effort of putting up the specs and information from Penrite on their website. It is the most comprehensive I have ever seen. However, their products does not look that impressive comparing to Mobil, Shell, Castrol, especially in HTHS, cts and TBS attributees.
I did state in my 1st post in this topic that i did not understand all the tecnichal side of the oil. But many thanks for now helping me out. I understood your reply much better than the 1st (correct or not haha).
Only 1 question,
You say the smaller the gap between the number the better, yeh?
if so, and your car heats up as much as mine (RB25 s1- in a 180sx), would i not be better going for a higher rated oil, like a 10w60? so as the car gets hot, it will thin out to like a 10w40?
or am i completly wrong, and it wont thin out that much, so a 0w40 would be ok?
p.s i will be going grade 4
p.p.s i will be getting an oil cooler in the coming months, but the car will see the track again before this happens.
How hot is hot?
Generally, HTHS of a 40wt oil is around 3.7 to 4 cP. That's is more than enough for RB engine on track, especially, if performance oil like 300V promoting 0% shear with good proportion of Grp IV, V base oil.
In terms of thinning, a 40wt and a 50wt thin down to a very similar viscosity in extreme heat temperature. However, a 50wt will have a thicker film thickness particularly in mixed boundary lubrication.
Don't see 60wt be used with any application in a Skyline. A bit extreme.
OK sweet as........ 0w50 is what im gunna get in a group IV. In the very 1st post it says that 0w40 thins down- and equates to about 20wt, which is not good for track use. At least the 50wt will give me a bit of head room.
Thanks to everybody that assisted me in understanding the whole oil thing.
Scott
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
