The regular t-shirts will be available in black, white, light grey, navy, red and blue. I will have to confirm the available colours in the long-sleeve t-shirt range. Black, white, light grey and navy shouldn't be a problem...
Blank ink will be used on the white and light grey and white ink be used on the other fabric colours.
  • Replies 184
We will definitely be going ahead with this latest design.
The cost will be $32.00 per t-shirt, or $36.00 for long-sleeves. This price includes postage (within Australia) as well as a $5.00 contribution to this forum. For those of you living outside of Australia, e-mail me and I will forward you a separate postage quote.
The t-shirts will be available in black, white, navy, light grey (marle), red and blue. The long sleeve t-shirts will be available in black, white, navy and light grey (marle). The white and light grey t-shirts will be printed using black ink, the other fabric colours will be printed using white. Keep in mind that the GT logo will not necessarily be black and white - it will be the ink colour against the t-shirt fabric colour.
We will be taking orders for probably around two weeks. Expect to see your t-shirt/s around 7-10 working days after this.
Edit: The t-shirts are rather large, so be sure to refer to the sizing chart when ordering.
How to order:
1.) Click to: http://tshirttext.com
2.) Browse to the SAU order page (linked from the home-screen).
3.) Complete and submit the order form.
4.) Wait for our e-mail, which will confirm your order and provide you with appropriate payment details.
5.) Submit your payment, together with a receipt number which we will provide in this confirmation e-mail.
It's as easy as that. You can monitor the status of your payment and order at any time by e-mailing us and quoting your order receipt number.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
