  • Replies 66
Knock on wood, nothing happened to me thank God.... Might have 1 or 2 chips on the bonnet but nothing major.. I was giving it to my car, in about 60% of the time i was in 3rd gear and 40% of the time in 2nd reving it up to 6000rpm on the GOR! The car seemed to love it and i didnt hesitate! :burnout:
On the way back it was fulll throtle, though suspensions are gay and the car feels like a boat when i do about 150-180km/h, sounds like my 2nd upgrade is going to be the suspension, then brakes upgrade to Brembo's!
Nothing like a good GOR run and back through th Otways to see if your car is upto scratch :O
mmm... some casualties indeed this time.
last time virtually no-one had after effects.
hopem it doesn't turn you guys off another GOR in the future.
well thing of it this way.. if the problems were there and they surfaced there, at least u guys know about them now :)
ur car seemed to go pretty well though max for a stocky, i don't think it can be anything *too* major?? it wasn't lacking power or anything going up those curves and things :O but i'd get a comp test just to be sure.
Monday morning to work (the day after) the car drives really sucks..... Gerald advised me to drive it gently, as I do now. It really like someone having a bad hangover the next morning...
Tuesday, oil level back up again, I can reach almost 6 when driving and above 2 when idle. Today is low again. Driving it gently feels fine, quite good actually, but not when the boost comes up, then all the flat spots are back laughing at you. Nothing I can do except just back it off and drive gently again.
Good for my fuel consumption though...
ur car seemed to go pretty well though max for a stocky, i don't think it can be anything *too* major.. it wasn't lacking power or anything going up those curves and things  but i'd get a comp test just to be sure.
true that, it didn't seem to struggle too much, but the misses have became more and more noticeable... i normally drive off boost anyway but yesterday i pushed it a very little bit against a clubsport and i felt like it dropped about 500 rpms at about 3500, so i backed off (and he thought he was king shit)...
and today, once warmed up, my oil pressure hardly passed 2kg/cm2!!!
anywho, tomorrow morning will give me an indication of whats going on in the RB.. hopefully nothing too serious
AAhh...
that's all good then... soon... (2-3 months) i'll do another... but i think a different route is in order.
New roads not even I have been down before :O
Maybe out Colac way, more otway fun.
But hhmm... it is a good test for the car and it's limits/condition.
no doubt about that.
Anyway but not the kingslake-healesville route.. went there once and the road condition was so terrible in the mountains, I think it'll destroy all your shocks. Very twisty though, for those who likes it but not much view and road is only 1-1/2 lane width which means if a large car comes from different direction you could scrape them.
Like you said R31, it is good to know what the limit of the car is and what's wrong with it if pushed hard.
I'll go for another cruise again, no probs hehe
My oil pressure seem to be find now and is it sitting at 2 when idling and 4 when cruising. Will still keep an eye on it, but it seem to drive fine.
dropped off my car to ice this morning, my oil pressure was normal all morning?? (2 at idle, 4 at accel), but it's getting looked at it anyway.
oh and what i thought is missing... gerald says its just my clutch on its way out :) (good to know but bad for $$$)
hopefully he doesn't call me back with more problems
Good News!!! Gerald has given my car a clean bill of health, said he couldn't find anything wrong with my oil pressure so its probably just the gauge acting up a bit.
My clutch is slipping a bit but only in higher gears at higher accel so it *should* last until i can afford to replace it.
In fact, the dodgiest thing about my car is the weird exhaust, that i will try to replace ASAP.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
