  • Replies 221
Here you go Steveo,
All i could find tonight. Only just got the dvd. I'll see if there is any more tomorrow arvo.
There's only a quick pass at the beginning, and then some smoke shows around the 1:30 mark. Unfotunately not from your tyres though. :)
It sounds like this....
bbbbbbbbbbbRrrrrrRRRRROOOOOOOOOOOOOOOOOMMMMMMMMMMMMMMMMMMMMMMMMM
WWWWWWWWWWW
WWWWWWWWWWW
WWWWWWWWWAAA
AAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAA
AAAAAA
LOLROFL N shit
and oh
LOL@ your av :)
Here you go Steveo,
There's only a quick pass at the beginning, and then some smoke shows around the 1:30 mark. Unfotunately not from your tyres though. :(
Thanks mate!
Some more incar from the ford.
more incar
Cool Vid, Especially like the part where you had the camera in teh passenger side footwell looking up at the driver..
What kind of camera's set up where you using for all of that??
I would love to see footage of me driving think it would be hilarious cause Brad and Neil both commented on my driving style..Neil wished I would sit back on my seat and Brad thinks I am really enthused behind the wheel :(
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
