Eric Medlen last year and now Scott Kalitta. After the death of Medlan I remember John Force withdrawing his car until he could make it safer against slapping the wall, but there are no mods to make a Funny Car safe from the impact that Scotty took. Longer run off is the key. It looked like a good pass too...RIP Scott
How horrible. Just watched the accident and there are a lot of questions to be asked. How horrible for his wife and two boys.
Re: the chutes, it appears that they tangled. They didn't burn up by the looks of it. It takes a lot of fire to burn them. When the body blows off it deploys the chutes automatically but they can still tangle.
^^^ yeah could be right re: shute, it's possible when the body came off he was knocked out...didn't seem to get off it at all after that moment. Damn shame.
Edited by madbung
I've got mates that either crew for or drive/own Nitro cars, a background in drag-bikes myself & this has been a concern of mine for a long time. Speeds have been getting faster, times have been getting quicker but nothing by & large has been happening to the braking area's at most tracks.
When Senna died, it forced the FIA to address run-off areas for hi-speed circuits, when Earnhardt died at Daytona NASCAR mandated HANS devices & finally implemented soft-walls on the Super-Speedways. When Darrell Russell was killed in Joe Amato's dragster a few yrs ago NHRA mandated shields around the rear of the cage around the drivers head along with tyre changes in conjunction with Goodyrear & when Eric Medlin died testing his Funny Car last yr, John Force Racing took it upon itself to design a safer cockpit which in turn is being mandated by the NHRA as well.
It makes me f**ken angry that has taken the death of yet another racer, but maybe Scott Kalitta's legacy will be the updating of emergency provisions at the end of drag-strips the world over. I know that sometimes there's nothing that can be done if a vehicle is carrying enough speed & energy off the end of the strip & Scott looked like he went into the sand pretty hard, but a lot of sand-traps are so ineffectul they may as well not even be there, incl in my opinion the one at E-town.
We as a species have developed the engineering knowledge & ability to achieve damn near anything, but ONLY when the cost of NOT DOING SO out-strips the cost of actually fixing the problem. How many more lives is it going to cost before this is addressed???
Yes we all die & yes Scott went out doing what he loved, but his death is still a pointless, needless & maybe even a preventable one. :D
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
