All,
What is the best way to remove the speed limiter from a 2003 V35 GT manual? I have searched and all I have found are "speed cut defenders are available", however I'm not overly sure what they are, where to get them and any negatives associated with them.
I am after the most reliable and cheapest method available without requiring a full ECU with the relevant tuning hassles. I do not intend to modify the car, just remove the speed limiter. I do not want to affect the fuel efficiency or any other tuning parameters the car.
Any suggestions including brands, suppliers and installers (preferably in SA) would be much appreciated.
Cheers.
Edited by Garage Menace
https://www.sau.com.au/forums/topic/225044-v35-speed-limiter/
All,
Cheers.
The speed cut defenders are what you're after. Just a colourful Japanese use of English.
They will simply do exactly what your after and your cheapest option.
Unless you decipher Chris' cryptic message and/or are as talented as him when it comes to electronics. :D
Chris is making this into a cryptic crossword puzzle!
I could have looked it up and told you which wire to tamper with..
need to make some of you think :D
one point I did miss though - auto or manual? if auto it may fool with the shifting and toss a code or two.
Edited by Chris Rogers
no. but someone saw my logic.
to be honest IF you clipped the wrong wire there is a good chance the car wouldn't move.
speed cut device would do nicely. unless somone can tell me the voltage and frequency the sender is operating at around that speed.
All,
Cheers.
HKS make a SLD for this. $445inc.
Cheers
Marty
Cutting wires doesnt require too much skill.. and if you cut the wrong one, then just solder it back again.
Ive clipped and spliced wires on my r33, when installing my apexi rsm to get rid of the speed limiter.
Not that hard, the apexi website gave me a diagram explaining what wire was what.
Took about 30 mins to install. and it worked perfectly! =)
Don't be too afraid to play around with your car! Its all about learning! hehe
Yeah im not surprised the V35 is more complicated... its a much newer car.
R33 is complicated enough for me! haha.
Anyway good luck!
But unless you gonna track it, cutting the speed limiter is not really needed.
top speed limit in WA is 110kmh.
going 180kmh+ on public roads is just f*cking stupid.
Everyone,
Thanks for the help, I think, though some of you are taking the piss... :)
Chris, I will freely admit I know nothing about car electronics, and have neither the time or inclination to learn, hence my question. Thatz where experts like you come in. Bombs and bullets, camouflage and concealment, rules of engagement, and fire and movement are my bread and butter...
Everyone, I welcome your continued input, and if anyone can advise of the cheapest reliable speed cut defender it would be appreciated.
Cheers.
PS. Itz for the track. I'm not an idiot.
PPS. Chris, itz a manual.
haha, glad to hear ur not an idiot
i would go the apexi rsm to get rid of the speed limiter.
Then you also get other features such as lap times / Qtr mile times and power output ratings (just a few of the features it offers)!
I got mind 2nd hand for 150$ plus the G sensor, which senses how much G force the car is experiencing.. helps to make more accurate readings.
tell that to one of the guys I do work for. have a van here (nissan thing) that I have to totally rework for htis market. has two screens and he wants the LOT to work here. so nav,tv,dvd, radio and a few extras. it has to be zoned as well. have it for as long as I need it thank god but its fun. put it this way I have a scope,sig gen,meter out pinning the thing out.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
