Hey,
IM wrecking a r33 1995 R33 manual coupe. it has exterior panel damage, everything else is in perfect working order.
Decided to strip.
below are pictures and prices of things that are for sale (( note not everything is listed, just Message me if u require something that isnt on the list.))
here is the list of things for sale, (( feel free to message me about prices, but i think they are fair.))
below the list is photographs off everytihng :( need any more information let me know.
Part Price
Manual Gear box 5 spd............... $1,800
rb25det engine ......................$2500
Clutch heavy duty .........................$700
HKS 2535 Turbo (sold separate or with engine up to you) ............................$1100 ish
Or all the above can be sold as a package, includes everything $4500
Do luck Rear cross bar (RXB) ..................$350
ARC Turnflow FMIC .................. $700
Apexi Rsm........................ $250
mines chipped stock ECU .................$350
Qauntum Fully adjustable suspension with spanners coilovers .....................$1200
turbo back 3.5inch exhaust .........................$700
Cusco strut bar.......................... $150
All interior peices please ask and offer Open to offers,
Skyline Origianl factory floor mats .....................................$100
HKS boost gauge ...........................$100
HKS boost controller ( whole unit, including engine bay solenoid ..........................$200 ,
Blitz turbo timer .........................$80
All glass perfect condition, make an offer Offer.
Boot lid, ( without wing) ............................$250
Rear spoiler lip style, (( damaged needs bogging etc .............................$150 ono
GT badges ............................$50 pair
Skyline Clear boot garnish ........................$80
Gear stick and hand brake leather cover $30 each or ........................$50 pair BRAND new condittion.
Gtr seat, Has some minor damage ............................... $260
B pillars (( the plastic between drivers window and rear quartes ......................$70
the A pillar.............................. $70 bucks without gauge
the dash ( tacho speedo etc)............................. $250
cross drilled brakes disc .................................$500
brake calipers great pads. ......................................$350
Enkei 17inch wheels .....................................$1500
passenger side mirror ....................................S120
passenger side front headlight ...........................$300
ARC radiator 36mm core great conditioon .............................$850 (cost $1180 dollars brand new, its in perfect condition)
R33 series 1 white Bonnet perfect condition ............................$400
air flow meter ( stock ) .........................S150
Hks Pod filter .................................$80
Pair white perfect condiiton rear tail lights .........................$600 For pair
rear indicators and reverse light ) driver side light damage $ make an offer
locked DIFF ............................ $800
Abs UNit, $ Make an offer
Passenger side door perfect condition ............................$300
Complete working electric antenna
Make an offer
Edited by Reevzy
my mate needs all the power steering lines (the solid ones and some of the flexible ones)
i mite also be interested in some bits for my 33 4door.
please pm me a price for the powersteering lines and contact number
cheers
matty
Still have this stuff for sale. plus heaps more not sold. engine, gearbox, clutch, mines ecu, front strut bar, front gaurd, calipers are gone. fmic, radiator, turbo timer still for sale. good left passenger door, bonnet and boot lid still for sale in good order. rear lights series 1 lefthand headlight. all glass except quarter windows. abs system and locked diff for sale. speedo assembly, boost gauge
post-44347-1215941367_thumb.jpg post-44347-1215941282_thumb.jpg post-44347-1215941243_thumb.jpg
Edited by Reevzy
Hey, always sad to see a wrecked skyline...
Im looking for: - Weather strips around both doors if they can be taken off without bending
- ARC intercooler best price?
- ABS unit, more importantly the ABS relay unit attached to the abs pump
Cheers
Craig
Cheers
Craig
only have the abs unit,not to keen to seperate that as someone may want it as a fully working unit
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
