Ok Ladies/gents,
Quick update as requested.
Traveling 400km a week sets me back approx $45.
LPG has been in the Stagea for about 8 Months with out any dramas what so ever.
I do run on petrol each day, generaly whilst the timer is running after the 45-60 min trip to work, Also 20mins a week on the M4.
Performance side of things runs almost the same as petrol, 0-20km is slightly less but if your just crusing of the lights you cant notice.
Normal driving 60km-110km its great, pulls nicely.
Cheers
Edited by hectic180
  • Replies 46
Posted Images
Surly the stagea doesn't use that much fuel that you have to get them converted to gas or am i missing something.
The reason i ask is i am looking at getting one (all going well) and all this talk of converting them to gas is getting me worrried
you have to remember that the stagea is a performance wagon.personally i dont think the economy is excessive.if you want economy buy a barina etc.i have a gas falcoon yooooot and is heaps cheaper to run than the petrol version.
Ok Ladies/gents,
Cheers
not to try to take anything from you - it sounds like you have a great result there...
but my average is also around 400km a week, and on my current fuel economy (12L/100km) that costs me ~$60-65 on average. My car is petrol only and this is for bp ultimate 98 fuel. I've thought of converting to dual fuel sometime but I'd need the difference to be much more than $15 a week to make it worthwhile.
It would depend on the type of traffic you drive in though, so if I were driving the same route as you I may well be using much more fuel.
mike40sydney - yes the stagea is a performance wagon, but I still feel that you can have both performance AND efficiency. With my last stagea I managed to increase the power by 40kw and lower my fuel economy by 2L/100km at the same time - through mods. Without mods, my current M35 is just as efficient as what my last one was with mods - and at ~12L/100km I think this is very similar to ford and holden wagons of the same year - and much better than other wagons with the same performance.
However that said, it is easy to use a lot of fuel in a turbo car - it requires a lot of self-control to keep the costs down and only hit boost occasionally. :bunny:
good luck changing the oil filter.
I too had that problem on my R34 sedan, after changing the filter twice from below (up between the block and suspension) I decided a remote oil filter was worth every penny. I boot mounted the battery, mounted catch can, oil filter and now have room for a 2nd convertor all with in the battery spot for when my new custom gas fuel rails are made up.
P.s i have since learnt that 200RWKW is the max for 6 injectors WITH STANDARD PRINS FUEL RAILS. the rail is the limiting factor.
my gas setup paid for it self very quickly, although i do have a very heavy right foot.
regards
Chris
FWIW, we have one V6 Adventra fleet car at work which averages 17L/100. Bear this in mind when you look at the consumption of our Japanese 1700kg AWD wagons...
(We're all chasing more power & economy, but ~12L/100 starts to look pretty good when compared with the Holden!)
My fuel economy in my Series 2 Dedicated Gas Stagea
Fuel Economy: City 17.8 litres/100 (330 km range). Highway 14.8 litres/100 (400 km range)
Cost per tankful $30.00 based on $50c/litre in VIC at the moment.
Based on price of LPG 2 weeks ago, it was costing $21.00 per tankful based on $35c/litre.
Heres a link to my thread with more details.
http://www.skylinesaustralia.com/forums/Lp...-2-t226938.html
Yes it is a tight squeeze to change the oil filter but have done it many times now and is do able in the factory location depending where, and how big your converter is.
45,000 trouble free klms thus far, paid back the system many times over already.
Most of the other people who have converted over and found a good tuner will tell you the same thing. I haven't come across anybody who has done it and has regretted their decision with these Skyline motors.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
