I am planning on doing some minor mods in the next month to my 34gtr so i dont blow the ceramic wheels of my turbo's through a perfectly good rb26! The car is seldom driven on the road and will see the track about once a month.
My thoughts are....
power fc
hks gtss turbos
700 cc injectors
cam gears and a tune!
What is a good [rapist!] mechanic/tuner going to charge me for this and what are your thoughts on the mods? keep in mind i dont want insane amounts of power, but i do want reliability.
all input would be appreciated, and i live on the gold coast if people could reccomend anyone..
Edited by Duncan1
Dont forget about a good oil cooler and maybe radiator to a lesser extent....
A good oil cooler is key when it comes to reliability on the track (and road)
Highly recomend the Greddy stuff, have one myself and its awsome
Edited by bnr#@
Thanks mate, what would be the cost installed for the cooler???
Why not do all of the work yourself.Its only bolt on stuff you are doing.
Then the tune will be the only thing you will have to pay for (and the tow to the tuners)
EDIT: You have a Prado and a 34GTR. Whats a few grand on mods and labour.
Mate, love the idea of saving money, but im an absolute spastic when it comes to anything like that! i would rather pay someone to get the job done properly! I dont want to spend anymore than around 6k, am i around the money?
I also have 2 properties with ridiculous mortgages, so i am trying to stick to a budget so i can eat each week!!! :sick:
turbos on/off should be around 1k labour. GT-SS come with all gaskets etc so no added cost there. (3k)
So 4k fitted or there abouts for turbos.
Tune 700, injectors take about 15mins so nothing major there, maybe new orings or something, cheap either way.
PFC 900
plus cam gears/fit another say 350-400 or so.
6k sounds reasonable, could be 500 or so more maybe, but its right on the ballpark
PFC 900
Thankyou for that, much appreciated! sounds like a plan. Any ideas if the old 34 turbos are worth re-selling? if so, what should they be worth?
Your old turbo's will be desirable for someone who has blow up their stockers or want a mild upgrade for a R32GTR.
Depending on condition ~ $500-800
Thanks mate, better than nothing. will help a little. will post some dyno sheets once its all done.. anyone know a good tuner/mechanic. i've heard Gavin Wood or Matty Spry? any previous experiance with either? anyone?
Edited by Duncan1
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
