I know not that many ppl go to night shift from SAU but for those that do i thought it would be thoughtful to post this up...
Night Shift is once again going to put on a event at Homebush Car park P6 meet at 7:30 JULY 3rd Tomorrow
fully sponsored event and import model Nikita
Edited by slverbullet
https://www.sau.com.au/forums/topic/226493-night-shift-event-3rd-of-july/
  • Replies 59
Posted Images
Pretty much... a very good friend of mine is a promoter for this, she knows me pretty well, and she said I probably wouldn't like it :D
Besides that and the late notice, I don't really want to be seen with misbehaving car enthusiasts :(
And I know it's a tiny percent that ruins it, but it's enough to gain attention...
anyone else went there only to find a closed gate and a shit load of undercovers booking everyone?
Yeah i was pretty much there , Lucky this guy came next to me and said to do a U Turn theres cops everywere , i done a U Turn on my way out seen cops everywere lucky i got out , Ended up cruising With a Blue 200 , White Evo, and a Yellow GTT , Anyone here ????
yea i got there and they closed the carpark...i was with wrx, a few 180sx's and others
then we drove outside acer arena and in a little while the whole road was packed with cars and 10 under covers defecting alot of show car and 2 or 3 riot squad vans came
was a pretty fun night...ill post my pics next week....my mate got a a SLR camera so most of the picks are good quality
the cops were bagging out the cars they were defecting......they said what and ugly paint job, what lame number plates and wat stupid mods to all the show cars....with 20" chromies and customs paint and interior
i guess the the show cars attracted soo much attention from the cops and the jdm style cars were fine though out the meet
well i was cruising with a white r34, black s2k and a wrx.. we pulled into the shops to have a coffee until one of them f***ers followed us in and got us all.
fkn worse night ever ! organisers are pretty dumb not to put any notice out of the closure. pretty much feels like a set up
Man i am so lucky some guy told me about it , i was like literally 30 seconds away from there ,
What you get done for ?
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
