Cheaper Price For Group Buy Of Hybrid Cooler Kit!!!! $1000
OK GUYS
I HAVE JUST GOT IN CONTACT WITH A SUPPLIER AND I CAN DO THIS KIT FOR THE LOW PRICE OF $1000 + POSTAGE THATS RIGHT $1000 + POSTAGE.
WHOLE FRONT MOUNT HYBRID INTERCOOLER KIT!!!!! PIPING, HOSES, HOSE CLAMPS AND COOLER!!!! 600X300X76 BAR AND PLATE.
PM ME WITH YOUR NAME AND NUMBER AND I WILL GIVE EACH ONE OF YOU A CALL.
EVERY1 CAN SAVE ANOTHER $100!!!!
LEGIT, NOT STOLEN!!!!!!
RECAP: S13,14,15 R32,33,34 HYBRID MONSTER COOLER KIT $1000
are these teh same as jets?
that is do they have the mounting brackets and instructions with the kit.
Will i have to buy any brackets to install the unit?
And im in perth too, so NO_RSPECT, we should strick up a deal...
Let me know Gixx88
Nate
yes same as JETS
yes alloy pipes
freight would be round $50?
just guess though
and as for how long its available, just guessing it would be a while, unless sold out
will find out freight aND availability very soon
thanks all
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
