holes in front bar...
ive noticed that on gt-r's the vspec's dont have these 'speed holes'.. but normal gt-r's do... i would have thought it would be the other way around if anything:)
R32 GT-R V-spec
R32 GT-R
same deal with 33's... havent looked at 34's though, probably the same.
https://www.sau.com.au/forums/topic/2271-holes-in-front-bar/#findComment-41696
hhmmm "speeeeed holes hey"???
Speed Holes.. how funny is that..
I thought the 2 holes were called N1 bumper inserts.
Isn't there an N1 version in all the GTR's
or did they just do that in the R34 and all the other GTR owners saw them and thought "sweet" I'll take 2 of those there speeeed holes..
I'm going home to take to my bonnet with a axe... I'm a get me some of them there speeed holes..
https://www.sau.com.au/forums/topic/2271-holes-in-front-bar/#findComment-41792
GTST there was an n1 in all models of the gtr, boo5t the cars you see that arent n1 with this they have been fitted later or the front bar has been replaced thats probs why you see more run of the mill R's with them these cars are more likely to have a new front bar.
https://www.sau.com.au/forums/topic/2271-holes-in-front-bar/#findComment-41821
officially they are called N1 front bar slots. i wouldn't mind getting those as a later addition to my car... they arent too much either. UAS quotes $100 for the fibreglass ones for an R32, which is cheap.... oh and of course fitting, dunno how much for that though... hehehe speed holes... from the simpsons! :)
https://www.sau.com.au/forums/topic/2271-holes-in-front-bar/#findComment-42066
from my understanding, R33 Series 3 GTR's have these in the bars as standard, of course N1 GTR's have them as well
Series 1 and Series 2 R33 GTR's don't have them (unless they are aftermarket / add on)
not sure on R32's or R34's.. but yeah they flow a little more air into the top of the intercooler,
i guess they may even increase flow into oil coolers as well depending on where they are fitted, but it is probably too low down for that..
https://www.sau.com.au/forums/topic/2271-holes-in-front-bar/#findComment-44039
Yeah on the r32 gtr they are from the N1 kit. Ive got em for my GTst which has original GTR bar, theyr bout 350 each side from nissan, but fortuantely I got em original for 250 together. They go with the N1 lip on the bonnet, N1 rear pod on side skirt, and the lip on the boot lid under the spoiler.
Mainly purley a look thing
Regards
Will
https://www.sau.com.au/forums/topic/2271-holes-in-front-bar/#findComment-44160
  • 3 weeks later...
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
