Thanks Guys,
The picture isn't perfect by any mean. It was one of those "still learning" picture.
But it just have a certain "mood" to it that I really like, but it is no where near what a professional photo would be.
As for the kit, it does have the Garage Yanack Fender.
The front bumper and side skirt is TBO
The front grill and rear wing is D-speed
The rear bumper is Do-Luck
The Bonnet is Speed-R
And wing mirror is Mine's
So it is a bit of a mix.
  • 3 weeks later...
my jaw dropped the moment i saw this car, seriously dropped, its such a beast!
hate to be picky but that tree's shadow just screws the awesome pic slightly
hmm, i see what you mean but at the same time, i think that it almost makes it look like the tree or something is creeping up to the car, it works kinda well i think
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
