Don't think it will remove the boost cut - because I think they don't have one.
thanks for the reply
installing my front mount upped boost to 10psi, after puting in a boost tee i had fuel cut with any increase above 10psi thought that might have been ecu over boost protection, but maybe its something else.
maybe aftermarket ecu is my only choice.
thanks again :(
https://www.sau.com.au/forums/topic/227482-r32gts4-remap/#findComment-4004463
I would pm CEF11E or drdrift. CEF11E is in Melbourne but he does do r32 remaps, and your 32 ecu would need a cradle put in etc. He does do tunes without dyno time as well. Think he was charging around 150$
i have a pre programmed eprom by some company called marobi, only cost $15
wasnt going to put it in but maybe it can solve my problems.
think its a bit dodge though as not tuned on my car
https://www.sau.com.au/forums/topic/227482-r32gts4-remap/#findComment-4004646
Have a chat to cef11e or drdrift, if your not happy with your current remap, as they both have a fair bit of experience, I have one in my car, any only reason I need to change it is due to having a boost leak when the car was dynoed. Ceff11e has done countless r32 remaps now.
https://www.sau.com.au/forums/topic/227482-r32gts4-remap/#findComment-4004663
    • I live in Quebec. Our license plate slogan is "Je me souviens" Translated is "We will remember" as a reminder to when England conquered us and that we must never forget what they did. Long story short, BSP is unheard of here due to being an English design. I'm surprised our nazi anti english government office the OQLF hasn't kicked in my door yet just talking about it, yet alone imperial anything.
    • Thanks for that! I did a quick Google search looked up some of hydaulic stores and didn't see it listed on the website, I'll give them a ring. Also found out later that I can buy 2 oem bleeder bolts for 10 bux and come with the washer which I might do so I don't waste the money it costs in petrol to find 2 washers (already did that lol). The old copper washes look in good nick, I drove it after taking it off and putting it back on and didn't see any  Part number here for reference if anyone needs: 14053-42L0A
    • Piggaz had one and broke it at 470kw
    • I'm going to assume they flipped it, as the timing setup in the AEM is catastrophically wrong. Once it is fixed, they'll likely need to swap it back to normal.
