For some reason I can't edit my previous post in this thread... Anyway, there is a small chance I could still make it but I won't know for sure until Monday (this coming Monday) so unless that's too late for booking an extra person I could still be in.
  • Replies 167
Posted Images
ill be there, not sure what ride though.
i have issues relaxing while my GTR sits out in a carpark out of view so probably will be in something else
i went to elizabeth shops last night to see the new batman (brilliant movie btw) i was paranoid as.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
Ă—
Ă—
