A summer Targa?
The Wrest Point Targa
Saturday, January 31 to
Sunday, February 1
TARGA – A NEW SUMMER ADVENTURE – Jan 31 to Feb 1, 2009
We understand (via a reliable source) that the promoters of Targa Tasmania plan to run a two day event based at the Wrest Point Hotel at the end of January in 2009. This would put the event a couple of weeks before Rally Tasmania. We understand that the course will involve some of the better stages taken from the old Day 3 of Targa in the Huon Valley and involve the use of a new stage some 32 km in length. What is most surprising is the reported entry fee is likely to be $1,800.00 or less. Watch this space, we will provide more detail as it becomes available.
I've heard whispers of it for some time now..... last I heard just awaiting the police ok which apparently was a formality :sleep:
I've already lined up somewhere to keep the car after this one until Targa :P (Assuming I'm not carrying it home in a suitcase.)
no news yet ben, but still progressing. all looking good. found me a gsr shell yet?
note to anyone - i need a registerable lancer cc gsr shell - pm me!
i'm in wa at australasian safari... tarmac rally regular tony quinn is running an ex-dakar swb pajero with mitsubishi gto (3ltr, v6, twin turbo) engine and was running sixth in his first attempt at off road until the engine shit itself. big night and day for the crew replacing it as not appear designed to be worked!
ps. wrest point targa.... what a good idea that would be. awkward sounding name though
yeah, its black and white now - vip on one side and frosty paws on the other.
lunched the replacment engine this morning so hes out now. according to nunny from lwr the cooling system just isn't very effecient so once thats sorted it should be half a thing.
they tapped the power well back when was running sixth too too so good form.
sorry steveo but not likely. about the only events that don't try for a level (ish) playing field by using the CAMS regs or similar are the lake mountain and mt buller sprints. and while they do pick up a few modified cars they loose a lot of people with cams regs cars. And the sad events last year suggest maybe some of the cars are too quick :)
anyone here get the facebook message (if your a member of the targa group) about wrestpoint targa? (yep working real hard at work today :dry:)
SCOOP
Targa Wrest Point is GO GO GO!
Octagon Australia plan to announce a 2nd Targa style event tomorrow morning to be held on 31st January & 1st February 2009 running out of Wrest Point in Hobart and using famous stages including Oyster Cove, Longley, Grasstree Hill and Cygnet.
The course will feature two never before used Targa stages each over 25km in length, making them the longest stages in the country outside of Targa Tasmania.
The organisers have gone crazy winding back the clock with an entry fee of less than $2,000!!! Targa Tasmania Early Bird entries can enter for as little as $1,590!!!
Entries to be limited to just 130 places and with 190 already entered for Targa Tasmania that can grab the cheap entry price, it will fill very fast.
Stand by…. The actual announcement will be posted here later today…
http://www.targawrestpoint.com.au/Competitors/Forms.html
good to see another octagon/aasa tarmac event.
Yup yup YUP!!!!!!
I'm just about to pull the trigger on entering........ Stu, if I enter now, can all the details be changed later?
Say, I enter my car as driver, then I decide to do it with Russ in the 35..... can we just swap all the details over? I wanna take advantage of the early bird entry for both.
And Stu... were you tryin to get a hold of me yesterday? Call me if ya need - 0438 830 641
Edited by Marlin
AWESOME Andrew!!! :ninja:
Have you thought about Targa? Decided to enter Rookie to see if you can win modern to get the full entry for 2010 or just goin the whole hog?
Edited by Marlin
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
