Well done Snowball, you'll be accepted in a heartbeat! :)
Accomodation suggestions (where I stay)
Targa Rookie;
During recce and up to morning of day 2 - The Olde Tudor Motor Inn (closest to Silverdome)
Night of day 2 into Hobart, Hotel 429 (across road from casino)
Wrest Point;
Again, Hotel 429 unless you're particularly monied and stay at the casino.
I know the course probably isn't confirmed at this stage, but I think you will find Targa Rookie starts and finishes in Launceston. So no need to move!
But seriously you guys doing the Rookie will LOVE it, easy event to step up into. I had a farken ball even though we finished closer to the bottom due to an engine failure on day 1.
I had an even bigger ball with Benny this year doin the full thing!
All good mate - I'll sus out the options for Launceston but I figure there isn't the panic there that there is for say Strahan. (Which I'm happy to know doesn't effect me for next year)
I'm guessing the best thing for Targa Tas is to get there on the Saturday right (Friday night boat) and have a look around for the weekend before all the offical stuff starts on Monday?
And also for Targa Wrest Point getting there Friday morning should be fine yeah - there's nothing other than Scrutiny on the Friday and there should be plenty of time to get from the boat to Hobart and have all that done on Friday. There is no Friday prologue or anything planned for running orders for it is there? (Stu!?)
I'm just trying to book all the boats, accomm and everything as I've been a classic in the past for not booking things in time for events and being left with a serious lack of options.
Targa Rookie course will be Launceston-Launceston. Yeah use the weekend to recce with Monday for more recce in between doco, scrutiny with breifing and the welcome function from 6:30 I think it will be.
Targa Wrest Point, correct no prologue... cars will be seeded instead (I'm open to bribes!). Friday for this event will be doco, scrutiny, brefing and welcome function.
So leave at least a solid day for a good recce Snowy for Wrest point, I'd recommend two days for you to settle in, have a beer etc....
It's GTR country down that way buddy! Nice n bumpy n grotty :banana:
I see you have commandeered Ness for a recce next month, fun fun! :D
Hey Ben I watched your George Town prologue footage on the weekend - geez that looks like a whole lot of fun. But also really suprising that it is allowed! LOL - I just can't imagine anyone on the main-land letting people do that.
Although someone needs to teach you how to edit your footage - the 2min wait at the start of each one is unnecessary :banana:
lol... yeah it's a bit of fun :banana:
Mt Buller last did a similar prologue in 2006, but apparently a couple of likely regulars were continually spinning/outbraking themselves and making it too dangerous.
Only the silly folk/heroes go really hard in prologue, as it doesn't leave you any buffer in front of the sweep car (at Targa and most others fastest prologue car leaves last). Get behind the sweep, she'll all over for the day.......
lol... by the way, how many seconds you reckon the missed gears cost us?
Haha - I didn't want to mention that little whoopsy :banana:
I just presumed you thought you may have been going a bit quick and wanted to lose a bit of time since it did happen near then end. That's how it was yeah!? :D
lol.. no, not at all :D Take a second look and see juuust how many there was :D Not making excuses, but I will anyway :banana: I hadn't driven the car since Dutton Vic, and there something definately wrong with the gearbox mount, or shifter ball, or something, coz it was bad! I struggled all Tugga and I'm not know for rushing gears...... and the crew didn't dig too deep looking... beers were more attractive it seems :(
Needs one of them flappy doober fandangle boxes eh benny?
Yeh good chat tossa! lol
Hey, as an aside, called Deano friday for a chat. He was picking up his "new" toy... not a tarmac rally car but still of interest I guess... if you like that kinda thing. And orange, you gotta like orange.
Should go a bit of alright at Sandown I reckon aye Snowy? :banana:
http://www.flickr.com/photos/8015926@N02/s...57601282088255/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
